<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MagicMover]]></title><description><![CDATA[<p dir="auto">Hi all!<br />
I recently made my first MagicMirror² addon. I call it <strong>MMM-MagicMover</strong>, and prevents screen burn-in.<br />
Installation and more information can be found here: <a href="https://github.com/Lavve/MMM-MagicMover" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Lavve/MMM-MagicMover</a></p>
<p dir="auto">What it does is to randomly and smoothly move each section a couple of pixels up/down/left/right.</p>
<p dir="auto">Suggestions for improvements are totally welcome. :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/13304/mmm-magicmover</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 22:17:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13304.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Jul 2020 13:17:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MagicMover on Thu, 13 Mar 2025 18:52:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/botts85" aria-label="Profile: botts85">@<bdi>botts85</bdi></a> said&gt;</p>
<p dir="auto">I tried it with:</p>
<pre><code>ignoredRegions: [".region.top.bar"],
<p dir="auto">and still no luck.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/c-son" aria-label="Profile: C-son">@<bdi>C-son</bdi></a> stated in his posting the region with single quotes…<br />
I‘m not really sure if this makes a difference - at least worth a trial…</p>
<pre><code>
 ignoredRegions: ['.region.top.bar'],
<p dir="auto">„Fullscreen_below“ BTW is not supported in ignoredRegions …</p>
<p dir="auto">Good luck.<br />
Regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/124854</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124854</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Thu, 13 Mar 2025 18:52:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Thu, 13 Mar 2025 17:38:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/botts85" aria-label="Profile: botts85">@<bdi>botts85</bdi></a> here is the defined terms for the ‘regions’<br />
from the doc</p>
<p dir="auto"><img src="/assets/uploads/files/1741887498631-img_0844.png" alt="IMG_0844.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/124852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124852</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Mar 2025 17:38:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Thu, 13 Mar 2025 17:21:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/c-son" aria-label="Profile: C-son">@<bdi>C-son</bdi></a> what format should the ignoredRegion field be in?</p>
<p dir="auto">I can’t seem to get it to ignore regions.  I’m trying this, but it’s still moving my background:</p>
<pre><code>                {
                        module: "MMM-MagicMover",
                                    updateInterval: 10 * 60 * 1000,
                                    ignoredRegions: ["fullscreen_below"],
                                    maxMove: 15,
                                    moveWholescreen: false,
]]></description><link>https://forum.magicmirror.builders/post/124850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124850</guid><dc:creator><![CDATA[botts85]]></dc:creator><pubDate>Thu, 13 Mar 2025 17:21:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Mon, 22 Feb 2021 16:31:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcaminiti" aria-label="Profile: mcaminiti">@<bdi>mcaminiti</bdi></a> said in <a href="/post/88774">MMM-MagicMover</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/c-son" aria-label="Profile: c-son">@<bdi>c-son</bdi></a> If I have a full screen background rotating from Bing or somewhere else, do you think that change is enough to prevent some burn in or would something like this still be helpful for clock, date and other things that maybe are always white and showing up.</p>
<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mcaminiti" aria-label="Profile: mcaminiti">@<bdi>mcaminiti</bdi></a>, yes, I believe this module will help to prevent screen burn in if you still have static text or images visible on the screen.</p>
<p dir="auto">Fairly new to MM and found this module which I think is great idea.</p>
<p dir="auto">Thank you! :thumbs_up_light_skin_tone:</p>
<p dir="auto">I didnt know if this burn in was common?</p>
<p dir="auto">Me neither. :) I just did this module to help those who might have this kind of issue. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/88778</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88778</guid><dc:creator><![CDATA[C-son]]></dc:creator><pubDate>Mon, 22 Feb 2021 16:31:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Mon, 22 Feb 2021 16:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/c-son" aria-label="Profile: c-son">@<bdi>c-son</bdi></a> If I have a full screen background rotating from Bing or somewhere else, do you think that change is enough to prevent some burn in or would something like this still be helpful for clock, date and other things that maybe are always white and showing up.</p>
<p dir="auto">Fairly new to MM and found this module which I think is great idea.  I didnt know if this burn in was common?</p>
]]></description><link>https://forum.magicmirror.builders/post/88774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88774</guid><dc:creator><![CDATA[mcaminiti]]></dc:creator><pubDate>Mon, 22 Feb 2021 16:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Fri, 19 Feb 2021 09:57:37 GMT]]></title><description><![CDATA[<p dir="auto">A new version of MMM-MagicMover is now released. Now you can add regions that shouldn’t be included, by adding them to an array:</p>
<pre><code class="language-javascript">{
    updateInterval: 60 * 1000,
    ignoredRegions: [],
    maxMove: 20,
<p dir="auto">Valid regions are: <code>'.region.top.bar'</code>, <code>'.region.upper.third'</code>, <code>'.region.middle.center'</code>, <code>'.region.lower.third'</code> and <code>'.region.bottom.bar'</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/88648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88648</guid><dc:creator><![CDATA[C-son]]></dc:creator><pubDate>Fri, 19 Feb 2021 09:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Thu, 27 Aug 2020 08:04:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> awesome, thanks for getting back to me!</p>
]]></description><link>https://forum.magicmirror.builders/post/80830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80830</guid><dc:creator><![CDATA[C-son]]></dc:creator><pubDate>Thu, 27 Aug 2020 08:04:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Thu, 27 Aug 2020 02:39:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/c-son" aria-label="Profile: C-son">@<bdi>C-son</bdi></a> Apparently, updates you did between my post and my capturing screen shots fixed it. It’s now working normally after another git pull.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/80826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80826</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 27 Aug 2020 02:39:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Wed, 26 Aug 2020 07:36:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> hard to say since I have no idea what other modules you’re using. It’s also hard to anticipate what and how other modules available for the Magic Mirror will affect Magic Mover. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/80779</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80779</guid><dc:creator><![CDATA[C-son]]></dc:creator><pubDate>Wed, 26 Aug 2020 07:36:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Mon, 24 Aug 2020 22:38:13 GMT]]></title><description><![CDATA[<p dir="auto">Installed new version today, and now the middle column of items are pushed way right. don’t seem like anything is moving around either.</p>
<p dir="auto">Anything I can do to fix it, or should I wait?</p>
]]></description><link>https://forum.magicmirror.builders/post/80698</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80698</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 24 Aug 2020 22:38:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Mon, 24 Aug 2020 19:02:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raymondjspigot" aria-label="Profile: raymondjspigot">@<bdi>raymondjspigot</bdi></a> thank you for your bug repport. I will try to find a solution for this.</p>
]]></description><link>https://forum.magicmirror.builders/post/80677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80677</guid><dc:creator><![CDATA[C-son]]></dc:creator><pubDate>Mon, 24 Aug 2020 19:02:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Thu, 13 Aug 2020 23:31:10 GMT]]></title><description><![CDATA[<p dir="auto">hi C-son thanks for your module, I’m just building and trying out my mirror and avoiding burn-in sounds like a great idea.</p>
<p dir="auto">I’ve been slowly configuring my mirror and started using the module MMM-BackgroundSlideshow as well.  I’m finding that if I enable MMM-MagicMover then my background images don’t show (I just get my Clock, Calendar modules etc. displaying on a black background).  If I disable MMM-MagicMover then the background images from MMM-BackgroundSlideshow are displayed under my other modules ok like before.</p>
<p dir="auto">Do you know if there’s a way to run both modules at the same time?  I’ve experimented with changing the module position values in my config.js but it didn’t seem to help.</p>
<p dir="auto">(My MMM-BackgroundSlideshow is in position: fullscreen_below incidentally)</p>
<p dir="auto">thanks for any help anyway</p>
]]></description><link>https://forum.magicmirror.builders/post/80152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80152</guid><dc:creator><![CDATA[raymondjspigot]]></dc:creator><pubDate>Thu, 13 Aug 2020 23:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Tue, 21 Jul 2020 19:03:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a> Thanks for feedback, and good luck with your daughters mirror :)</p>
]]></description><link>https://forum.magicmirror.builders/post/78991</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78991</guid><dc:creator><![CDATA[C-son]]></dc:creator><pubDate>Tue, 21 Jul 2020 19:03:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MagicMover on Tue, 21 Jul 2020 16:04:05 GMT]]></title><description><![CDATA[<p dir="auto">Hmm very usefull module here thanks.</p>
<p dir="auto">It will come very handy once I’ve setup my daughter 24/7 smart mirror!</p>
]]></description><link>https://forum.magicmirror.builders/post/78982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78982</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Tue, 21 Jul 2020 16:04:05 GMT</pubDate></item></channel></rss>
