<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[G-assistant and Spotify]]></title><description><![CDATA[<p dir="auto">Has anyone faced any issue with google assistant and Spotify as in, while playing any music on Spotify on the magicmirror, if I activate the google assistant, it interacts with me in normal volume but later on  the volume of the music goes to 100% post google assistant interaction.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13309/g-assistant-and-spotify</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 20:54:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13309.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Jul 2020 10:18:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to G-assistant and Spotify on Fri, 24 Jul 2020 19:35:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> thank you 🤩</p>
]]></description><link>https://forum.magicmirror.builders/post/79120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79120</guid><dc:creator><![CDATA[sdmydbr]]></dc:creator><pubDate>Fri, 24 Jul 2020 19:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to G-assistant and Spotify on Fri, 24 Jul 2020 13:41:47 GMT]]></title><description><![CDATA[<p dir="auto"> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdmydbr" aria-label="Profile: sdmydbr">@<bdi>sdmydbr</bdi></a> : Corrected with v2.3.3 of A2D</p>
]]></description><link>https://forum.magicmirror.builders/post/79109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79109</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 24 Jul 2020 13:41:47 GMT</pubDate></item><item><title><![CDATA[Reply to G-assistant and Spotify on Fri, 24 Jul 2020 04:29:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> thanks for looking into it, I hope it will be fixed soon</p>
]]></description><link>https://forum.magicmirror.builders/post/79102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79102</guid><dc:creator><![CDATA[sdmydbr]]></dc:creator><pubDate>Fri, 24 Jul 2020 04:29:06 GMT</pubDate></item><item><title><![CDATA[Reply to G-assistant and Spotify on Mon, 20 Jul 2020 12:15:38 GMT]]></title><description><![CDATA[<p dir="auto">hi, yes it’s +/- a tmp bug</p>
<ul>
<li>A2D control librespot device.</li>
<li>I reduce the volume (<code>minVolume</code>) on google response</li>
<li>I put <code>maxVolume</code> on standby</li>
</ul>
<p dir="auto">todo:<br />
-&gt; I have to register actual volume before reduce volume<br />
-&gt; I have to set old volume value on standby mode</p>
<p dir="auto">note: <code>maxVolume</code> and <code>minVolume</code> is on <code>spotify: {}</code> field of A2D Config</p>
]]></description><link>https://forum.magicmirror.builders/post/78905</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78905</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 20 Jul 2020 12:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to G-assistant and Spotify on Mon, 20 Jul 2020 07:22:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> I don’t know how to figure out the problem.<br />
So I have tried various combinations such as<br />
G-assistant(phone)+Spotify (phone)= fine<br />
Assistant (mirror)+Spotify(phone)=fine<br />
Spotify(mirror)+assistant (phone=fine<br />
Assistant (mirror)+Spotify (mirror)= volume increases to 100%</p>
<p dir="auto">And then I tried with android tv<br />
Spotify (tv) + assistant (tv) = fine<br />
Assistant (mobile) + Spotify (tv)= fine<br />
Spotify (phone) + assistant (tv)= fine<br />
Spotify (mirror) + assistant (tv)= fine<br />
Assistant (mirror) + Spotify (tv) = volume increases to 100%.</p>
<p dir="auto">Try to reproduce this issue, I can only conclude that there might be some bug in the google assistant module.</p>
]]></description><link>https://forum.magicmirror.builders/post/78897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78897</guid><dc:creator><![CDATA[sdmydbr]]></dc:creator><pubDate>Mon, 20 Jul 2020 07:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to G-assistant and Spotify on Mon, 20 Jul 2020 02:59:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> I really can’t figure out what issue is that. For instance I was playing Spotify in my android tv in another room, when I run the google assistant in my mirror, after interacting with the assistant  the volume of the Spotify on my android tv goes to 100% in my android tv, same case of I’m playing Spotify on my mirror, the volume goes to 100%. I don’t know how to figure out the problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/78892</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78892</guid><dc:creator><![CDATA[sdmydbr]]></dc:creator><pubDate>Mon, 20 Jul 2020 02:59:39 GMT</pubDate></item><item><title><![CDATA[Reply to G-assistant and Spotify on Sun, 19 Jul 2020 12:01:08 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure that’s an MMM-GoogleAssistant or Spotify issue ?<br />
because natively MMM-GoogleAssistant can’t control Spotify volume</p>
]]></description><link>https://forum.magicmirror.builders/post/78861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78861</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 19 Jul 2020 12:01:08 GMT</pubDate></item></channel></rss>
