<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar entries wich repeated annually]]></title><description><![CDATA[<p dir="auto">Since the update to version v2.12.0 I have problems with my all day appointments in the calendar module.<br />
I have found out that if for example a birthday has not set a repetition, then everything fits. The birthday is announced correctly and “Birthday xy Tomorrow” and on the day of the birthday it shows: “Birthday xy Today”.<br />
However, if I set the date to be repeated annually, the date no longer fits. The appointment is displayed one day too early as “Today” and on the correct day the appointment does not appear any more.</p>
<p dir="auto">my config:</p>
<p dir="auto">…<br />
{<br />
module: “calendar”,<br />
header: “Kalender Familie”,<br />
position: “top_left”,<br />
config: {<br />
tableClass: “medium”,<br />
maximumEntries: 15,<br />
maxTitleLength: 50,<br />
wrapEvents: “true”,<br />
timeFormat: ‘absolute’,<br />
dateFormat: ‘Do MMM HH:mm’,<br />
urgency: 0,<br />
calendars: [<br />
// Familie<br />
{<br />
symbol: “calendar”,<br />
url: “<a href="https://myurl" target="_blank" rel="noopener noreferrer nofollow ugc">https://myurl</a>:port/caldav///”,<br />
auth: {<br />
user: “”,<br />
pass: “”,<br />
method: “basic”,<br />
}<br />
},<br />
…</p>
]]></description><link>https://forum.magicmirror.builders/topic/13317/calendar-entries-wich-repeated-annually</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 03:36:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13317.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jul 2020 10:08:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar entries wich repeated annually on Fri, 04 Sep 2020 14:50:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thiske" aria-label="Profile: thiske">@<bdi>thiske</bdi></a> see the post at the top of the troubleshooting section for the temp fix til next release.</p>
]]></description><link>https://forum.magicmirror.builders/post/81276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81276</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 04 Sep 2020 14:50:02 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar entries wich repeated annually on Fri, 04 Sep 2020 14:29:13 GMT]]></title><description><![CDATA[<p dir="auto">i, am following this tread, i have the same problem. when the appointment is repeated its change by time.  example:<br />
appointment x at 10 o’clock tomorrow non repeat --&gt; MM say’s 10 o’clock<br />
appointment x at 10 o’colck tomorrow and repeat every day --&gt; mm say’s 9 o’clock</p>
]]></description><link>https://forum.magicmirror.builders/post/81274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81274</guid><dc:creator><![CDATA[thiske]]></dc:creator><pubDate>Fri, 04 Sep 2020 14:29:13 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar entries wich repeated annually on Tue, 21 Jul 2020 13:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/torte22" aria-label="Profile: torte22">@<bdi>torte22</bdi></a> if u can find the old iCal.js, maybe</p>
]]></description><link>https://forum.magicmirror.builders/post/78973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78973</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 21 Jul 2020 13:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar entries wich repeated annually on Tue, 21 Jul 2020 06:56:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank’s for the information, good to know where problem is located. Is it possible to switch back and use the old library in my running installation?</p>
]]></description><link>https://forum.magicmirror.builders/post/78960</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78960</guid><dc:creator><![CDATA[torte22]]></dc:creator><pubDate>Tue, 21 Jul 2020 06:56:53 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar entries wich repeated annually on Mon, 20 Jul 2020 11:10:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/torte22" aria-label="Profile: torte22">@<bdi>torte22</bdi></a> they updated the calendar entry parser library this release, and the new version is not better than the old one we had.</p>
<p dir="auto">there is some work going on to resolve this, but not fixed yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/78903</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78903</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Jul 2020 11:10:56 GMT</pubDate></item></channel></rss>
