<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Smarttouch module with any kind of IR frame?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have a short question about the smarttouch module. I’m planning to build a mirror with it, but wonder, if the module (and the Raspberry pi for that matter) is compatible with any IR touch frame (Xintai or ZZD in particular, because they are the only ones I found in 24 Inches).<br />
Thank you very much in advance,</p>
<p dir="auto">kind regards,<br />
Henning</p>
]]></description><link>https://forum.magicmirror.builders/topic/13319/smarttouch-module-with-any-kind-of-ir-frame</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 14:47:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13319.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jul 2020 15:11:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Smarttouch module with any kind of IR frame? on Tue, 25 Aug 2020 05:39:57 GMT]]></title><description><![CDATA[<p dir="auto"><em>Update</em><br />
I used this guide to setup calibration:<br />
<a href="https://www.thingsconnected.io/raspberry-pi-7-inch-touch-screen-calibration/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.thingsconnected.io/raspberry-pi-7-inch-touch-screen-calibration/</a></p>
<p dir="auto">Also, despite the manufacturer saying only supports 1 point on Linux, I definitely see multi-point, tried with six fingers using this site:<br />
<a href="https://paveldogreat.github.io/WebGL-Fluid-Simulation/" target="_blank" rel="noopener noreferrer nofollow ugc">https://paveldogreat.github.io/WebGL-Fluid-Simulation/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80719</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80719</guid><dc:creator><![CDATA[jimbydude]]></dc:creator><pubDate>Tue, 25 Aug 2020 05:39:57 GMT</pubDate></item><item><title><![CDATA[Reply to Smarttouch module with any kind of IR frame? on Sun, 23 Aug 2020 05:26:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/henning" aria-label="Profile: Henning">@<bdi>Henning</bdi></a> I’m not at home for next couple days but i got the 43" IR frame from Shenzhen on ali (I’m pretty sure is same one).</p>
<p dir="auto">I’m running mm on pi 4. The frame worked out of box, didn’t need to install anything, however finding calibration info was difficult. I can post more detailin that once home.</p>
<p dir="auto">Having said that it was pretty close without calibrating.</p>
]]></description><link>https://forum.magicmirror.builders/post/80598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80598</guid><dc:creator><![CDATA[jimbydude]]></dc:creator><pubDate>Sun, 23 Aug 2020 05:26:31 GMT</pubDate></item></channel></rss>
