<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM2 shows only Time (worked some minutes ago)]]></title><description><![CDATA[<p dir="auto">Hello there,</p>
<p dir="auto">i was installing Mm2 today and tried out some modules.<br />
All was working fine (except Octoprint Stream) and then from one minute to the other all modules were hidden or not shown on the screen except the clock with date</p>
<p dir="auto">Here you can see my config.js (also resetted again and after putting in a new module same error as above)<br />
What am i doing wrong or where is the mistake?</p>
<p dir="auto">also if i start “npm install” then a lot of errors appear</p>
 * By Michael Teeuw https://michaelteeuw.nl
 * MIT Licensed.
var config = {
	address: "localhost", 	// Address to listen on, can be:
	port: 8080,
	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
	language: "en",
	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			module: "compliments",
			position: "middle-center"
			module: "currentweather",
				locationID: "2835481", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				appid: "700d5aff6db1410f7ab49da88d0933b8"
			module: "weatherforecast",
			header: "Wetter Vorschau",
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "New York Times",
						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
                module: "MMM-Fuel",
                position: "top_left",
                config: {
                    api_key: "d5b40c42-68d4-3767-d7ac-c118ba7a169a",
                    lat: 49.099680,
                    lng: 9.837190,
                    types: ["e5", "diesel"],
                    sortby: "e5",
                    radius: 10,
                    max: 5,
                    rotateInterval: 120000,
                    updateInterval: 900000
                    module: "MMM-Todoist",
                    position: "bottom_right",   // This can be any of the regions. Best results in left or right regions.
                    header: "Todo-Liste", // This is optional
                    config: { // See 'Configuration options' for more information.
                        hideWhenEmpty: true,
                        accessToken: "55fa7b89de14c3d232890748370f2a9c2f296ce5",
                        maximumEntries: 60,
                        updateInterval: 10*60*1000, // Update every 10 minutes
                        fade: false,
                            // projects and/or labels is mandatory:
                        projects: [ 2239986494 ],
                        labels: [ "noch zu erledigen" ] // Tasks for any projects with these labels will be shown.
]]></description><link>https://forum.magicmirror.builders/topic/13336/mm2-shows-only-time-worked-some-minutes-ago</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 19:13:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13336.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jul 2020 14:56:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM2 shows only Time (worked some minutes ago) on Thu, 23 Jul 2020 16:29:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> that was added to the default config in. 2.12</p>
]]></description><link>https://forum.magicmirror.builders/post/79074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79074</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Jul 2020 16:29:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM2 shows only Time (worked some minutes ago) on Thu, 23 Jul 2020 15:54:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zebaztian" aria-label="Profile: ZebAztian">@<bdi>ZebAztian</bdi></a> Any reason you have the following in you config?<br />
<code>useHttps: false, 		// Support HTTPS or not, default "false" will use HTTP 	httpsPrivateKey: "", 	// HTTPS private key path, only require when useHttps is true 	httpsCertificate: "", 	// HTTPS Certificate path, only require when useHttps is true</code></p>
]]></description><link>https://forum.magicmirror.builders/post/79073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79073</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Thu, 23 Jul 2020 15:54:49 GMT</pubDate></item></channel></rss>
