<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LIRC Automation using PIR Sensor?]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/13349/lirc-automation-using-pir-sensor</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 17:35:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13349.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 25 Jul 2020 20:23:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LIRC Automation using PIR Sensor? on Sun, 26 Jul 2020 16:03:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sranj" aria-label="Profile: sranj">@<bdi>sranj</bdi></a> u will have to write code. some module or module extension. I think. I’ve said all the words that could be used in Google searches to figure it out.</p>
]]></description><link>https://forum.magicmirror.builders/post/79171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79171</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Jul 2020 16:03:56 GMT</pubDate></item><item><title><![CDATA[Reply to LIRC Automation using PIR Sensor? on Sun, 26 Jul 2020 15:19:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That could work, big question here though, how would I do that?</p>
]]></description><link>https://forum.magicmirror.builders/post/79170</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79170</guid><dc:creator><![CDATA[sranj]]></dc:creator><pubDate>Sun, 26 Jul 2020 15:19:18 GMT</pubDate></item><item><title><![CDATA[Reply to LIRC Automation using PIR Sensor? on Sun, 26 Jul 2020 01:00:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sranj" aria-label="Profile: sranj">@<bdi>sranj</bdi></a></p>
<p dir="auto">the sensor raises a signal pi pin when it senses infrared. after a small amount of time NOT sending infrared, it lowers the signal, ready to check again.</p>
<p dir="auto">usually software sets a timer, and when the timer expires, the timer signal does some work too.</p>
<p dir="auto">in this case, after 15 minutes of no motion, the timer signals no one is around, so does the turn off procedure. which u say already works</p>
<p dir="auto">so maybe the PIR sensor raises the pin, which triggers a routine, and that routine is a wake-up to send the ir command</p>
]]></description><link>https://forum.magicmirror.builders/post/79156</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79156</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Jul 2020 01:00:34 GMT</pubDate></item><item><title><![CDATA[Reply to LIRC Automation using PIR Sensor? on Sun, 26 Jul 2020 00:42:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sranj" aria-label="Profile: sranj">@<bdi>sranj</bdi></a> REALIZED MY QUESTION WAS NOT CLEAR I’m at a roadblock right now because I don’t know how to make this happen, if anyone knows what to do to make the PIR trigger the IR, please let me know!</p>
]]></description><link>https://forum.magicmirror.builders/post/79154</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79154</guid><dc:creator><![CDATA[sranj]]></dc:creator><pubDate>Sun, 26 Jul 2020 00:42:23 GMT</pubDate></item><item><title><![CDATA[Reply to LIRC Automation using PIR Sensor? on Sun, 26 Jul 2020 00:40:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Just realized I didn’t make my question clear in the post. I’m at a roadblock right now because I don’t know how to make this happen, do you happen to know a way for me to make the PIR trigger the IR?</p>
]]></description><link>https://forum.magicmirror.builders/post/79153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79153</guid><dc:creator><![CDATA[sranj]]></dc:creator><pubDate>Sun, 26 Jul 2020 00:40:11 GMT</pubDate></item><item><title><![CDATA[Reply to LIRC Automation using PIR Sensor? on Sat, 25 Jul 2020 20:55:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sranj" aria-label="Profile: sranj">@<bdi>sranj</bdi></a> cool… nice work… hope it completes well for you!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/79147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79147</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Jul 2020 20:55:49 GMT</pubDate></item></channel></rss>
