<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magicmirror in QNAP Containerstation installation]]></title><description><![CDATA[<p dir="auto">Hello, I wanted to ask if anyone has experience with the Magicmirror2 as Dockerimage in the QNAP container station. I have a Qnap 1079Pro with the container station in operation. Pihole is currently running smoothly in the container station. Now I wanted to install the Magicmirror as Docker in order to have a test environment so as not to shoot my Rapberry mirror through games and updates.</p>
<p dir="auto">Does anyone know how to install the image and what settings have to be made?</p>
<p dir="auto">I was able to download the image to the container station, what do I have to do when I create the container?<br />
How do I adjust the paths for the config, modules and css?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13351/magicmirror-in-qnap-containerstation-installation</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:14:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13351.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Jul 2020 06:48:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magicmirror in QNAP Containerstation installation on Sun, 26 Jul 2020 18:29:11 GMT]]></title><description><![CDATA[<p dir="auto">Hello sdetweil, for you as experts it shouldn’t be a problem to start the Docker, as a beginner I can only do a limited amount with the instructions. When I start the Docker via the Shell I get the following error message:<code> container-station/docker: Error response from daemon: driver failed programming external connectivity on endpoint magic_mirror (6372ebe4277aea6a53fc9129dcfe8c145b3010217241886e1ec5eb7ef103b8b1): listen tcp 0.0.0.0:80: bind: address already in use.</code></p>
<p dir="auto">When I call the Docker via the container station, the MagicMirror server is started, but I cannot connect to the web browser.<br />
“ERR_CONNECTION_REFUSED”</p>
<p dir="auto">I will read about Container Station, Docker in the next few days, maybe I’ll still get it to work.</p>
]]></description><link>https://forum.magicmirror.builders/post/79185</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79185</guid><dc:creator><![CDATA[Tribun]]></dc:creator><pubDate>Sun, 26 Jul 2020 18:29:11 GMT</pubDate></item><item><title><![CDATA[Reply to Magicmirror in QNAP Containerstation installation on Sun, 26 Jul 2020 11:58:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tribun" aria-label="Profile: Tribun">@<bdi>Tribun</bdi></a> I thought the doc was pretty clear<br />
<a href="https://github.com/bastilimbach/docker-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bastilimbach/docker-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/79167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79167</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 26 Jul 2020 11:58:23 GMT</pubDate></item></channel></rss>
