<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Fuel does not show any data]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I am quite new to MagicMirror and added some modules successfully, but currently I am struggling with MMM-Fuel. No gas stations are shown at all.</p>
<p dir="auto">This is my config:</p>
<pre><code>{
module: "MMM-Fuel",
//types: ["diesel"],
//provider: "tankerkoenig",
api_key: "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxx",
lat: "52.285583",
lng: "6.835616"
<p dir="auto">I can not find any errors in the development window</p>
]]></description><link>https://forum.magicmirror.builders/topic/13356/mmm-fuel-does-not-show-any-data</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 03:34:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13356.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jul 2020 06:28:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Thu, 30 Jul 2020 12:52:16 GMT]]></title><description><![CDATA[<p dir="auto">Thank you all for  your help.</p>
<p dir="auto">It finally worked,<br />
I don’t know why, but my coordinates were wrong.<br />
I thought I copied them correctly from another source, but I did not.</p>
]]></description><link>https://forum.magicmirror.builders/post/79363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79363</guid><dc:creator><![CDATA[phistix]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Thu, 30 Jul 2020 10:46:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thgmirror" aria-label="Profile: thgmirror">@<bdi>thgmirror</bdi></a></p>
<p dir="auto">Exactly, that would have been my next theory, check the coordinates and I think you have to specify a type (diesel).</p>
]]></description><link>https://forum.magicmirror.builders/post/79351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79351</guid><dc:creator><![CDATA[CanbiZ]]></dc:creator><pubDate>Thu, 30 Jul 2020 10:46:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Thu, 30 Jul 2020 08:16:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/phistix" aria-label="Profile: phistix">@<bdi>phistix</bdi></a> ,</p>
<p dir="auto">when I check your “lat” and “lng” you have in your config, it looks you are located in the netherlands…may be therefor, tankerkönig has no data for this place. So please check it again:-)</p>
<p dir="auto">Greetings from Bonn<br />
Thomas</p>
]]></description><link>https://forum.magicmirror.builders/post/79347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79347</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Thu, 30 Jul 2020 08:16:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Thu, 30 Jul 2020 07:23:10 GMT]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">thanks for the answers.</p>
<p dir="auto">I start mm via pm2.<br />
pm2 logs --lines=100 shows me no errors.<br />
Development windows doesn’t show me errors as well.</p>
<p dir="auto">I tried with a second API key, but still not working. And yes I confirmed the email.<br />
<img src="/assets/uploads/files/1596089493003-spritpreise.png" alt="spritpreise.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I installed manually “fs-extra” and “node-fetch” and I did a npm install in the MMM-Fuel folder, but it did not change anything.<br />
Can I somehow “uninstall” the module and the needed packets to restart from scratch?</p>
<p dir="auto">Und ja, ich bin deutsch <a class="plugin-mentions-user plugin-mentions-a" href="/user/canbiz" aria-label="Profile: CanbiZ">@<bdi>CanbiZ</bdi></a> :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/79345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79345</guid><dc:creator><![CDATA[phistix]]></dc:creator><pubDate>Thu, 30 Jul 2020 07:23:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Wed, 29 Jul 2020 13:27:34 GMT]]></title><description><![CDATA[<p dir="auto">Hey!</p>
<p dir="auto">Have you confirmed the e-mail? Otherwise the API key cannot be used. I just did it yesterday for my test project on a VM, it worked without problems.<br />
I can send you a screenshot to show you. I guess you must have made a little mistake somewhere.</p>
<p dir="auto">I just sat down and requested a new API key, this one works too.</p>
<p dir="auto">It’s my first post, so I had to wait 10 minutes. In this time I made a screenshot for you :-)</p>
<p dir="auto"><img src="https://i.imgur.com/uMwFojC.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">(im an German, if you are too, you can write me in german :-P )</p>
]]></description><link>https://forum.magicmirror.builders/post/79320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79320</guid><dc:creator><![CDATA[CanbiZ]]></dc:creator><pubDate>Wed, 29 Jul 2020 13:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Wed, 29 Jul 2020 13:22:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phistix" aria-label="Profile: phistix">@<bdi>phistix</bdi></a> so, lets look at the logs. how do you start mm? npm start or pm2</p>
<p dir="auto">if pm2, then<br />
pm2 logs --lines=100<br />
will show the node_helper messages</p>
<p dir="auto">if npm start, then the messages will be shown in the terminal window where u issued the npm start command.<br />
u may have to minimize mm to see that window (alt-spacebar, n to minimize)</p>
<p dir="auto">we also need to look at the browser messages, by opening the developers window. ctrl-shift-i, then select the tab labeled console and scroll up to see any error messages. you can also filter messages to a particular module, by putting part of the module name in the filter field, fuel, in this case.</p>
<p dir="auto">did u do the npm install after doing the git clone?, as the module depends on some libraries not avail by just install</p>
]]></description><link>https://forum.magicmirror.builders/post/79319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79319</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 29 Jul 2020 13:22:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Wed, 29 Jul 2020 12:51:10 GMT]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">yes, I’ve tried to remove the // parts and the API is inserted as well.<br />
It still does not work :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/79318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79318</guid><dc:creator><![CDATA[phistix]]></dc:creator><pubDate>Wed, 29 Jul 2020 12:51:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel does not show any data on Wed, 29 Jul 2020 09:21:18 GMT]]></title><description><![CDATA[<p dir="auto">Uncomment (remove) the // from types and provider.<br />
I suppose you registered on <a href="http://tankerkoenig.de" target="_blank" rel="noopener noreferrer nofollow ugc">tankerkoenig.de</a> and obtained an actual API key and are not running with xxxxxxx-xxx-xxx API key?</p>
]]></description><link>https://forum.magicmirror.builders/post/79314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79314</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Wed, 29 Jul 2020 09:21:18 GMT</pubDate></item></channel></rss>
