<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nixie Clock]]></title><description><![CDATA[<h1>MMM-Nixie-Clock</h1>
<p dir="auto">This is a module for the <a href="https://github.com/MichMich/MagicMirror/" target="_blank" rel="noopener noreferrer nofollow ugc">MagicMirror²</a>.</p>
<p dir="auto"><a href="https://github.com/nikobix/MMM-Nixie-Clock" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nikobix/MMM-Nixie-Clock</a></p>
<p dir="auto"><img src="/assets/uploads/files/1596005364368-5616b38e-97c5-41ff-b39e-f293e7195dda-image.png" alt="5616b38e-97c5-41ff-b39e-f293e7195dda-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><s>This module will float over other moudules, so you may need to adjust the position in the config file.</s> (Fixed this now)</p>
<p dir="auto">Using the module - moment.js<br />
Images found at:<br />
© 2007-08 Cestmir Hybl, <a href="mailto:cestmir.hybl@nustep.net" target="_blank" rel="noopener noreferrer nofollow ugc">cestmir.hybl@nustep.net</a><br />
<a href="http://cestmir.freeside.sk/projects/dhtml-nixie-display" target="_blank" rel="noopener noreferrer nofollow ugc">http://cestmir.freeside.sk/projects/dhtml-nixie-display</a><br />
and<br />
<a href="https://github.com/McOrts/M5StickC_Nixie_tube_Clock" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/McOrts/M5StickC_Nixie_tube_Clock</a></p>
<p dir="auto">To use this module, add the following configuration block to the modules array in the <code>config/config.js</code> file:</p>
<pre><code class="language-js">var config = {
            module: 'MMM-Nixie-Clock',
            position:"top_left",
            size: 75,            ** CSS automatically sizes the image size - 10%
]]></description><link>https://forum.magicmirror.builders/topic/13366/nixie-clock</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 17:38:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13366.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Jul 2020 06:51:10 GMT</pubDate><ttl>60</ttl></channel></rss>
