<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My first Magic Mirror build in an old imac]]></title><description><![CDATA[<p dir="auto">Here is my build.<br />
I wanted my MM more like a dashboard, so i choose an old imac because of the space behind the screen to fit everything in.</p>
<p dir="auto"><img src="/assets/uploads/files/1596044920657-60336bed-3371-4145-98be-5ceb54fe6ef6.jpeg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1596045052555-618668f0-80d7-4e20-92a3-d816f888445c.jpeg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">I reused the atx and the speakers.<br />
bought on ebay a display controller to hook the display up with the Raspberry.<br />
Connect a PIR sensor and 12v to 5v converter.<br />
Also used a max9744 amp to power the speakers.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13369/my-first-magic-mirror-build-in-an-old-imac</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 23:11:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13369.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Jul 2020 18:08:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Fri, 04 Jun 2021 07:23:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keaghoul" aria-label="Profile: keaghoul">@<bdi>keaghoul</bdi></a> first of all you need check the model nr. of the screen. its probably an LG screen, but i don’t know the model nr.<br />
with that you can look on Ebay for a display controller for that particular screen.</p>
<p dir="auto">if the PSU is still oke you kan use that one. you have to check which outlet is 12V+ continue is. and you can power the screen with that.<br />
also you need a inverter from 12v to 5v for the Raspberry.</p>
<p dir="auto">if you wan’t to use the the speakers u need also en simple AMP i use the TDA7297, i used a other one before but that one gives a white noise.</p>
]]></description><link>https://forum.magicmirror.builders/post/91869</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91869</guid><dc:creator><![CDATA[diemen112]]></dc:creator><pubDate>Fri, 04 Jun 2021 07:23:18 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Mon, 17 May 2021 04:19:47 GMT]]></title><description><![CDATA[<p dir="auto">First off, apologies for the necrobump — didn’t see a rule against it &amp; did see the prompt but didn’t feel this warranted a new topic. Apologies if this is a breach of rules or etiquette here.</p>
<p dir="auto">Anyway, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a>, I just came into an incredibly similar model (2006 iMac per the box, not sure of the specific model yet — diving into it tomorrow) without a motherboard, and my immediate thought was to turn it into an MM, leading me here. Wondering if you’d be down to do a quick rundown of your build or would be open to any question I might have after I take it apart tomorrow?</p>
<p dir="auto">Thanks much!</p>
]]></description><link>https://forum.magicmirror.builders/post/91487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91487</guid><dc:creator><![CDATA[keaghoul]]></dc:creator><pubDate>Mon, 17 May 2021 04:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 23:29:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/diemen112" aria-label="Profile: diemen112">@<bdi>diemen112</bdi></a> That’s default calendar module that comes with MagicMirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/79396</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79396</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Thu, 30 Jul 2020 23:29:30 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 23:28:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a> MMM-DarkSkyForecast</p>
]]></description><link>https://forum.magicmirror.builders/post/79395</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79395</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Thu, 30 Jul 2020 23:28:59 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 14:23:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/diemen112" aria-label="Profile: diemen112">@<bdi>diemen112</bdi></a> Honestly, that all looks like CSS</p>
]]></description><link>https://forum.magicmirror.builders/post/79368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79368</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 30 Jul 2020 14:23:25 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 11:51:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
And the calander module with the colors?!</p>
]]></description><link>https://forum.magicmirror.builders/post/79356</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79356</guid><dc:creator><![CDATA[diemen112]]></dc:creator><pubDate>Thu, 30 Jul 2020 11:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 09:14:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a> said in <a href="/post/79339">My first Magic Mirror build in an old imac</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a> said in <a href="/post/79335">My first Magic Mirror build in an old imac</a>:</p>
<p dir="auto">I’ve been doing the same thing with a 20" white Intel iMac, but have had one helluva time. None of the display controllers work with the native LG 1600x1050 display Apple put in these things, so I’ve basically gutted the iMac and am putting in a new display, etc.</p>
<p dir="auto">Not to hijack the thread, but this is how mine turned out.</p>
<p dir="auto"><img src="/assets/uploads/files/1596070276498-img_2387.jpg" alt="IMG_2387.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">also not wanting to hijack thread… but what weather module are you using? :)</p>
<p dir="auto">thanks</p>
<p dir="auto">Richie</p>
]]></description><link>https://forum.magicmirror.builders/post/79348</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79348</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Thu, 30 Jul 2020 09:14:42 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 00:51:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a> said in <a href="/post/79335">My first Magic Mirror build in an old imac</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/79339</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79339</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Thu, 30 Jul 2020 00:51:22 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Thu, 30 Jul 2020 00:43:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/diemen112" aria-label="Profile: diemen112">@<bdi>diemen112</bdi></a> Tried four different ones, all allegedly specific to the LM201W01 SL A3 that was in the iMac. None worked.</p>
]]></description><link>https://forum.magicmirror.builders/post/79338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79338</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Thu, 30 Jul 2020 00:43:29 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Wed, 29 Jul 2020 23:51:14 GMT]]></title><description><![CDATA[<p dir="auto">nicely done.</p>
]]></description><link>https://forum.magicmirror.builders/post/79337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79337</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 29 Jul 2020 23:51:14 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Wed, 29 Jul 2020 23:27:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a> i think this is the one you need.</p>
<p dir="auto"><a href="https://www.ebay.com/itm/HDMI-DVI-VGA-LCD-Lvds-Driver-Controller-Board-for-LM201W01-SLC1-LM201W01-SL-C1/313112850369?hash=item48e6faefc1:g:FakAAOSww2he4gaG" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ebay.com/itm/HDMI-DVI-VGA-LCD-Lvds-Driver-Controller-Board-for-LM201W01-SLC1-LM201W01-SL-C1/313112850369?hash=item48e6faefc1:g:FakAAOSww2he4gaG</a></p>
]]></description><link>https://forum.magicmirror.builders/post/79336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79336</guid><dc:creator><![CDATA[diemen112]]></dc:creator><pubDate>Wed, 29 Jul 2020 23:27:41 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Wed, 29 Jul 2020 22:52:26 GMT]]></title><description><![CDATA[<p dir="auto">I’ve been doing the same thing with a 20" white Intel iMac, but have had one helluva time. None of the display controllers work with the native LG 1600x1050 display Apple put in these things, so I’ve basically gutted the iMac and am putting in a new display, etc.</p>
]]></description><link>https://forum.magicmirror.builders/post/79335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79335</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Wed, 29 Jul 2020 22:52:26 GMT</pubDate></item><item><title><![CDATA[Reply to My first Magic Mirror build in an old imac on Wed, 29 Jul 2020 20:50:29 GMT]]></title><description><![CDATA[<p dir="auto">Very cool, even though I despise Apple. Ha</p>
]]></description><link>https://forum.magicmirror.builders/post/79333</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79333</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Wed, 29 Jul 2020 20:50:29 GMT</pubDate></item></channel></rss>
