<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-KeyBindings Error]]></title><description><![CDATA[<p dir="auto">Hi,<br />
ive installed mmm-keybindings and ive got it working the way i want but ive just noticed that when i start MM i get this error:</p>
<pre><code>[2020-07-31 20:27:28.838] [ERROR]  Whoops! There was an uncaught exception...
[2020-07-31 20:27:28.845] [ERROR]  Error: Cannot find module 'evdev'
Require stack:
- /home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js
    at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Function.Module._load (internal/modules/cjs/loader.js:531:27)
    at Module.require (internal/modules/cjs/loader.js:685:19)
    at require (internal/modules/cjs/helpers.js:16:16)
    at Class.startEvdevMonitor (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:61:17)
    at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:99:22)
    at Socket.&lt;anonymous&gt; (/home/pi/MagicMirror/js/node_helper.js:112:11)
    at Socket.emit (events.js:200:13)
    at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
    at processTicksAndRejections (internal/process/task_queues.js:82:9) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js',
    '/home/pi/MagicMirror/js/app.js',
    '/home/pi/MagicMirror/js/electron.js',
    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
    undefined
[2020-07-31 20:27:28.861] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2020-07-31 20:27:28.874] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
<p dir="auto">i dont think it affects MM but id like to get rid of it coming up, any help is much apprecated!</p>
<p dir="auto">Richie</p>
]]></description><link>https://forum.magicmirror.builders/topic/13378/mmm-keybindings-error</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:11:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13378.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jul 2020 08:25:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-KeyBindings Error on Sat, 01 Aug 2020 09:46:23 GMT]]></title><description><![CDATA[<p dir="auto">ive figured it out… just had to add the line:</p>
<pre><code>evdev: {enabled: false],
]]></description><link>https://forum.magicmirror.builders/post/79450</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79450</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Sat, 01 Aug 2020 09:46:23 GMT</pubDate></item></channel></rss>
