<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pjestico&#x2F;MMM-GoogleTrafficTimes Address Format?]]></title><description><![CDATA[<p dir="auto">No errors, but I can’t get data to display. Google API key is right, so I am looking for format errors. Anything obvious?:</p>
<pre><code>		{
            		module: 'MMM-GoogleTrafficTimes',
            		position: 'top_right',
                		key: 'AIzaSyAlettersandnumbersfYyA',
                		origin: '39.408476,-76.545179',
                		destination1: 'M Work:39.439013,-76.632005',
                		destination2: 'C Work:39.399357,-76.593041',
                		AvoidHighways: false,
                		AvoidTolls: false,
]]></description><link>https://forum.magicmirror.builders/topic/13407/pjestico-mmm-googletraffictimes-address-format</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 23:08:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13407.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Aug 2020 23:30:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Tue, 25 Aug 2020 17:06:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a>  open the developers window on the mirror, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors, usually red text.</p>
<p dir="auto">you should see a message about the API usage</p>
]]></description><link>https://forum.magicmirror.builders/post/80744</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80744</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Aug 2020 17:06:57 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Tue, 25 Aug 2020 17:04:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> not sure what ‘is binding’ means, but if means ‘is required’, then yes.<br />
Google requires an active functioning credit card, so IF/when you go over their credits they can charge you.</p>
<p dir="auto">as compared to a free account, until it runs out and doesn’t work anymore.</p>
<p dir="auto">they want it to keep working</p>
]]></description><link>https://forum.magicmirror.builders/post/80743</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80743</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Aug 2020 17:04:36 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Tue, 25 Aug 2020 15:54:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/80216">pjestico/MMM-GoogleTrafficTimes Address Format?</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> what is your config for this module? did u setup the google account and credit card required?  per the instructions?</p>
<p dir="auto">HI ,</p>
<p dir="auto">Account payment is binding?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/80738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80738</guid><dc:creator><![CDATA[Fonfon]]></dc:creator><pubDate>Tue, 25 Aug 2020 15:54:59 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Sun, 16 Aug 2020 14:13:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> what is your config for this module? did u setup the google account and credit card required?  per the instructions?</p>
]]></description><link>https://forum.magicmirror.builders/post/80216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80216</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 16 Aug 2020 14:13:57 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Sun, 16 Aug 2020 13:34:20 GMT]]></title><description><![CDATA[<p dir="auto">hi,</p>
<p dir="auto">Problem Nothing happens after installing the module …<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/80213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80213</guid><dc:creator><![CDATA[Fonfon]]></dc:creator><pubDate>Sun, 16 Aug 2020 13:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Mon, 03 Aug 2020 23:55:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmer3" aria-label="Profile: cmer3">@<bdi>cmer3</bdi></a> yeh, Google wants a good account payment method up front, even tho they will give u uncharged access for a while</p>
]]></description><link>https://forum.magicmirror.builders/post/79659</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79659</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Aug 2020 23:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Mon, 03 Aug 2020 23:53:20 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, looks like my issues is setting up billing on the google account</p>
]]></description><link>https://forum.magicmirror.builders/post/79657</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79657</guid><dc:creator><![CDATA[cmer3]]></dc:creator><pubDate>Mon, 03 Aug 2020 23:53:20 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Mon, 03 Aug 2020 23:52:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmer3" aria-label="Profile: cmer3">@<bdi>cmer3</bdi></a> I would guess origin  values wrong. that is a string</p>
<p dir="auto">I think if it’s lat/long it needs to be that structure</p>
<p dir="auto"><a href="https://developers.google.com/maps/documentation/javascript/examples/map-latlng-literal" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.google.com/maps/documentation/javascript/examples/map-latlng-literal</a></p>
]]></description><link>https://forum.magicmirror.builders/post/79655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79655</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Aug 2020 23:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to pjestico&#x2F;MMM-GoogleTrafficTimes Address Format? on Mon, 03 Aug 2020 23:44:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmer3" aria-label="Profile: cmer3">@<bdi>cmer3</bdi></a> open the developers window ctrl-shift-i and select the console tab and scroll up to see any errors</p>
<p dir="auto">also, please use the code block.markers for config.js entries.</p>
]]></description><link>https://forum.magicmirror.builders/post/79654</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79654</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Aug 2020 23:44:56 GMT</pubDate></item></channel></rss>
