<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Few issues]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’ve recently set up my mirror on a Pi running Pixel (is this the issue)</p>
<p dir="auto">But changing the code for Screen saver &amp; autostart hasnt worked.</p>
<p dir="auto">Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1342/few-issues</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 05:12:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1342.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Jan 2017 09:35:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Few issues on Mon, 09 Jan 2017 09:28:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">thats the post i followed, and have followed twice. The code is saving in the files I.e. the step below all saves and stays in the auto start config but doesnt do anything</p>
<p dir="auto">I’m either missing something glaringly obvious …</p>
<p dir="auto">Step 3<br />
Let’s disable the screen saver and screen blanking as well. This needs to be done in two places. First in the autostart configuration:<br />
‘sudo nano /etc/xdg/lxsession/LXDE-pi/autostart’</p>
<p dir="auto">And add the following to the bottom of the file:</p>
<p dir="auto">@xset s noblank<br />
@xset s off<br />
@xset -dpms</p>
]]></description><link>https://forum.magicmirror.builders/post/10689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10689</guid><dc:creator><![CDATA[CCoates]]></dc:creator><pubDate>Mon, 09 Jan 2017 09:28:21 GMT</pubDate></item><item><title><![CDATA[Reply to Few issues on Sat, 07 Jan 2017 04:31:34 GMT]]></title><description><![CDATA[<p dir="auto">I suggest that you use the following it’s a great way to get it up and running <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial</a></p>
]]></description><link>https://forum.magicmirror.builders/post/10536</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10536</guid><dc:creator><![CDATA[impuislupus]]></dc:creator><pubDate>Sat, 07 Jan 2017 04:31:34 GMT</pubDate></item></channel></rss>
