<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic mirror with 2 displays]]></title><description><![CDATA[<p dir="auto">hello everyone, I am making a Magic Mirror with an rpi4 and 2 screens that I place on top of each other. When I run the Magic Mirror software, it only shows on 1 screen. Is there a possibility to do this on the 2 screens?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13431/magic-mirror-with-2-displays</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 23:46:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13431.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Aug 2020 12:45:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic mirror with 2 displays on Fri, 14 Aug 2020 11:06:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> try 8090</p>
]]></description><link>https://forum.magicmirror.builders/post/80172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80172</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Aug 2020 11:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Fri, 14 Aug 2020 08:07:23 GMT]]></title><description><![CDATA[<p dir="auto">no problem, I should have looked at the console output earlier. would you just like to tell me which other port I can choose?</p>
]]></description><link>https://forum.magicmirror.builders/post/80163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80163</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Fri, 14 Aug 2020 08:07:23 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Thu, 13 Aug 2020 14:45:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> u have to change the port on the second one as well</p>
<p dir="auto">sorry, looking back I didn’t mention that</p>
]]></description><link>https://forum.magicmirror.builders/post/80128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80128</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Aug 2020 14:45:26 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Thu, 13 Aug 2020 08:30:56 GMT]]></title><description><![CDATA[<p dir="auto">There is an error in the second console output. This one:</p>
<pre><code>listen EADDRINUSE:  address already in use  128.0.0.1:8080
]]></description><link>https://forum.magicmirror.builders/post/80126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80126</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Thu, 13 Aug 2020 08:30:56 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Wed, 12 Aug 2020 14:26:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> can u show the two console outputs</p>
]]></description><link>https://forum.magicmirror.builders/post/80090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80090</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Aug 2020 14:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Wed, 12 Aug 2020 14:24:24 GMT]]></title><description><![CDATA[<p dir="auto">thats correct!</p>
]]></description><link>https://forum.magicmirror.builders/post/80089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80089</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Wed, 12 Aug 2020 14:24:24 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Wed, 12 Aug 2020 14:23:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> makes no sense. u are doing</p>
<pre><code>cd ~/MagicMirror1
npm start
<p dir="auto">in another window</p>
<pre><code>cd ~/MagicMirror2
npm start
<p dir="auto">right</p>
]]></description><link>https://forum.magicmirror.builders/post/80088</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80088</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Aug 2020 14:23:29 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Wed, 12 Aug 2020 14:14:26 GMT]]></title><description><![CDATA[<p dir="auto">I have done that but it still uses 1 config file. I have found that it always uses the config file of the MagicMirror that I run first.</p>
]]></description><link>https://forum.magicmirror.builders/post/80087</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80087</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Wed, 12 Aug 2020 14:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Wed, 12 Aug 2020 13:56:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> from the separate  mm installation  folders, right</p>
<p dir="auto">~/MagicMirror<br />
and<br />
~/MagicMirror2</p>
<p dir="auto">assuming there is a coding error someplace, rename like this</p>
<p dir="auto">~/MagicMirror1<br />
and<br />
~/MagicMirror2</p>
<p dir="auto">then there is no, MagicMirror folder to use from</p>
]]></description><link>https://forum.magicmirror.builders/post/80086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80086</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Aug 2020 13:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Wed, 12 Aug 2020 13:44:27 GMT]]></title><description><![CDATA[<p dir="auto">I used npm start to start both displays</p>
]]></description><link>https://forum.magicmirror.builders/post/80085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80085</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Wed, 12 Aug 2020 13:44:27 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Tue, 11 Aug 2020 18:02:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> hm… then they should be looking at the config folder under each separate mm folder</p>
<p dir="auto">u cannot start it twice from the same folder</p>
]]></description><link>https://forum.magicmirror.builders/post/80067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80067</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 18:02:54 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Tue, 11 Aug 2020 17:08:10 GMT]]></title><description><![CDATA[<p dir="auto">I have done npm start on both</p>
]]></description><link>https://forum.magicmirror.builders/post/80066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80066</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Tue, 11 Aug 2020 17:08:10 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Tue, 11 Aug 2020 11:44:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> how did u start each mm?</p>
]]></description><link>https://forum.magicmirror.builders/post/80038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80038</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 11:44:24 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Tue, 11 Aug 2020 08:16:32 GMT]]></title><description><![CDATA[<p dir="auto">I found the error, because I put the 2 screens on top of each other, not x but y = 1920.<br />
But I have found that the magicmirror2 folder is listening for the config file of the magicmirror folder. How can I adjust this?</p>
]]></description><link>https://forum.magicmirror.builders/post/80034</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80034</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Tue, 11 Aug 2020 08:16:32 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Mon, 10 Aug 2020 13:58:17 GMT]]></title><description><![CDATA[<p dir="auto">hm, this is mine, cut and paste, opens on second display</p>
<pre><code>
var config = {
  electronOptions: { x: 1920},
<p dir="auto">are you using docker or MagicMirrorOS</p>
]]></description><link>https://forum.magicmirror.builders/post/79958</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79958</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Aug 2020 13:58:17 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Sun, 09 Aug 2020 12:51:26 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the quick respons<br />
Yes, exact like that.</p>
]]></description><link>https://forum.magicmirror.builders/post/79956</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79956</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Sun, 09 Aug 2020 12:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Sun, 09 Aug 2020 12:37:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> like this, inside the config structure</p>
<pre><code>var config={
   electronOptions:{ x: 1920 },
    modules :[],
]]></description><link>https://forum.magicmirror.builders/post/79953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79953</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 09 Aug 2020 12:37:35 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Sun, 09 Aug 2020 12:19:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I addded <code>electronOptions: {x: 1920}</code> to my config file and I didn’t get an error but it still only shows up on the first screen. Am I doing something wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/79952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79952</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Sun, 09 Aug 2020 12:19:20 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Sat, 08 Aug 2020 15:01:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a> yes, rename one MagicMirror folder to MagicMirror2 and install a second instance, and in the config.js of one use the<br />
electronOptions:{x:1920}<br />
to display beyond the 1st display</p>
]]></description><link>https://forum.magicmirror.builders/post/79929</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79929</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 08 Aug 2020 15:01:28 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Sat, 08 Aug 2020 07:58:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for your quick and very complete answer. But do I understand that it is not possible to run the software on 2 screens? Could it be possible to run a separate magic mirror on each screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/79918</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79918</guid><dc:creator><![CDATA[Ety60]]></dc:creator><pubDate>Sat, 08 Aug 2020 07:58:01 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Fri, 07 Aug 2020 19:05:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a>   i have played with all kinds of scripts that ‘should’ work, but don’t… all oldish 2-3 years</p>
]]></description><link>https://forum.magicmirror.builders/post/79905</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79905</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 07 Aug 2020 19:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror with 2 displays on Fri, 07 Aug 2020 15:30:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ety60" aria-label="Profile: Ety60">@<bdi>Ety60</bdi></a>  I haven’t been able to make it use both displays on startup… I can drag the image to fill both screens…</p>
<p dir="auto">you can fiddle with the display options</p>
<pre><code>var config = {
     electronOptions : { ????? },
     modules : []
<p dir="auto">x and y describe the top left corner of the display<br />
width and height describe the size and shape of the page</p>
<p dir="auto">kiosk mode  turns on fullscreen, no title bar, and some other things, not resizable I think… really a pain on mac)</p>
<p dir="auto">the defintion of these options are here</p>
<p dir="auto"><a href="https://www.electronjs.org/docs/api/browser-window" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.electronjs.org/docs/api/browser-window</a></p>
<p dir="auto">I use the electronOptions to have MM run on the second display on my desktop system</p>
<p dir="auto">electronOptions: { x: 1920 },</p>
<p dir="auto">so I tried</p>
<pre><code> electronOptions: { x: 0, width: 1920, height: 2160, minHeight: 2160, kiosk: false, fullscreen: false,  backgroundColor: "#00000001", autoHideMenuBar :true},
<p dir="auto">and it starts fullscreen on the 1st monitor (had to crop the screen shot to get it under 2 meg)<br />
<img src="/assets/uploads/files/1596807462757-screenshot-at-2020-08-07-08-34-36-resized.png" alt="Screenshot at 2020-08-07 08-34-36.png" class=" img-fluid img-markdown" /><br />
and</p>
<pre><code>electronOptions: { x: 1920, width: 1920, height: 2160, minHeight: 2160, kiosk: false, fullscreen: false,  backgroundColor: "#00000001", autoHideMenuBar :true},
<p dir="auto">and it starts large, on the second monitor, but not quite full screen as the taskbar is not present on monitor 2.<br />
<img src="/assets/uploads/files/1596807487411-screenshot-at-2020-08-07-08-35-02-resized.png" alt="Screenshot at 2020-08-07 08-35-02.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">neither the system , nor MM know about the physical placement of the displays</p>
]]></description><link>https://forum.magicmirror.builders/post/79902</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79902</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 07 Aug 2020 15:30:36 GMT</pubDate></item></channel></rss>
