<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[after 2.12 upgrade custom.css is no longer loading]]></title><description><![CDATA[<p dir="auto">I updated to 2.12 tonight. my custom.css is not loading anymore. I opened the mirror in a brower and viewed the source and I see that a change has been made. In 2.11 the actuall custom.css appeared before the body opening html tag. But now I see this message in the html code.</p>
<pre><code>&lt;!-- custom.css is loaded by the loader.js to make sure it's loaded after the module css files. --&gt;
<p dir="auto">Obviously loader.js isn’t actually loading the custom.css.</p>
<p dir="auto">If I manually open the custom.css in my browser and then reload the mirror (in the same browser) I do see my custom css. It is upon the first loading of the mirror when it starts up that custom.css is not loading.</p>
<p dir="auto">In electron when it is started upon booting the pi, the loader isn’t loading the custom.css. and I do not see my custom css. I plugin in a keyboard and can force refresh. but this isn’t how I want the mirror to run. and I Don’t want to have to plug in a keyboard every time the power goes out. I live in the country and that happens often enough to be irritating here.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13433/after-2-12-upgrade-custom-css-is-no-longer-loading</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 16:54:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13433.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Aug 2020 07:30:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to after 2.12 upgrade custom.css is no longer loading on Thu, 27 Aug 2020 17:06:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kayakbabe" aria-label="Profile: kayakbabe">@<bdi>kayakbabe</bdi></a> cool, thanks for posting a resolution…</p>
]]></description><link>https://forum.magicmirror.builders/post/80849</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80849</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 27 Aug 2020 17:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to after 2.12 upgrade custom.css is no longer loading on Thu, 27 Aug 2020 16:49:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kayakbabe" aria-label="Profile: kayakbabe">@<bdi>kayakbabe</bdi></a></p>
<p dir="auto">For anyone who finds this thread,</p>
<p dir="auto">my solution was just to reinstall everything. Apparently I messed up some code somewhere else. My custom.css was fine and I used it on the fresh install.</p>
]]></description><link>https://forum.magicmirror.builders/post/80848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80848</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Thu, 27 Aug 2020 16:49:22 GMT</pubDate></item><item><title><![CDATA[Reply to after 2.12 upgrade custom.css is no longer loading on Sun, 09 Aug 2020 06:43:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I did the update manually. though I did install with your script when I first set it up.<br />
I have really been messing with it tonight and I have touched the custom css.<br />
to reduce the body margins.</p>
<p dir="auto">drwxr-xr-x  2 pi pi 4096 Aug  8 23:50 ./<br />
drwxr-xr-x 17 pi pi 4096 Aug  8 23:48 …/<br />
-rw-r–r--  1 pi pi 1059 Aug  8 23:50 custom.css<br />
-rw-r–r--  1 pi pi 2957 Jul 22 06:21 main.css</p>
<p dir="auto">I also added the grove_gestures and page and page indicator modules.<br />
I’ll back those out and see what happens with the custom.css.</p>
]]></description><link>https://forum.magicmirror.builders/post/79949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79949</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Sun, 09 Aug 2020 06:43:29 GMT</pubDate></item><item><title><![CDATA[Reply to after 2.12 upgrade custom.css is no longer loading on Sat, 08 Aug 2020 12:10:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kayakbabe" aria-label="Profile: kayakbabe">@<bdi>kayakbabe</bdi></a> show the messages from the developers window ctrl-shift-i on keyboard, then select the console tab and scroll up user any errors.</p>
<p dir="auto">how did u do the update? manually or the new script?</p>
<p dir="auto">in either case custom.css is not touched.</p>
<p dir="auto">also show results of this</p>
<pre><code>cd ~/MagicMirror/css
ls -laF
]]></description><link>https://forum.magicmirror.builders/post/79926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79926</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 08 Aug 2020 12:10:42 GMT</pubDate></item></channel></rss>
