<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not able to delete a file from raspbian]]></title><description><![CDATA[<p dir="auto">Hi. I have successfully  finished making a smart mirror. Now I actually want a voice assistant which can be used to interact with the smart mirror. So I have decided to integrate alexapi into my smart mirror.  This is the actual link from where I want to download alexapi :- (<a href="https://github.com/alexa-pi/AlexaPi/wiki/Installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/alexa-pi/AlexaPi/wiki/Installation</a>)<br />
So while I was installing this,  By mistakely I have closed the terminal so again when I tried to run the script, it was unable to execute so I decided to remove the file which I have cloned earlier while downloading the alexapi. This was the repo which I have cloned :- (sudo git clone <a href="https://github.com/alexa-pi/AlexaPi.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/alexa-pi/AlexaPi.git</a>). I have cloned this repo inside opt directory. So now my main problem is that as I have mentioned above that due to some reason I wanted to delete this file but I am unable to do so. The reason to delete the alexapi file is because I want to reinstall the alexapi. So when I again tried to clone the repo inside opt file, I am getting a error that the file you want to clone already exists and the directory is also  not empty so I have decided to delete the previous alexapi file but I was not able to remove the file. I always get the error that the file was deleted with errors and again when I go back and check that is the file deleted or no, so the answer is its not deleted. When I try to remove the file it says me this error that the file was deleted with errors. I hope you understood my problem. Please help me with it.<br />
Thanks in advance,<br />
stay safe</p>
]]></description><link>https://forum.magicmirror.builders/topic/13445/not-able-to-delete-a-file-from-raspbian</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 02:14:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13445.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Aug 2020 11:12:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Not able to delete a file from raspbian on Thu, 13 Aug 2020 12:59:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you. I have successfully deleted the file. Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/80131</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80131</guid><dc:creator><![CDATA[biswajeet]]></dc:creator><pubDate>Thu, 13 Aug 2020 12:59:41 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to delete a file from raspbian on Wed, 12 Aug 2020 13:10:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/biswajeet" aria-label="Profile: biswajeet">@<bdi>biswajeet</bdi></a> yes</p>
<p dir="auto">sudo rm filename<br />
sudo rm -rf foldername</p>
]]></description><link>https://forum.magicmirror.builders/post/80084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80084</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Aug 2020 13:10:11 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to delete a file from raspbian on Wed, 12 Aug 2020 05:22:06 GMT]]></title><description><![CDATA[<p dir="auto">So is there any way to remove the file?</p>
]]></description><link>https://forum.magicmirror.builders/post/80080</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80080</guid><dc:creator><![CDATA[biswajeet]]></dc:creator><pubDate>Wed, 12 Aug 2020 05:22:06 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to delete a file from raspbian on Tue, 11 Aug 2020 11:43:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/biswajeet" aria-label="Profile: biswajeet">@<bdi>biswajeet</bdi></a> opt is protected, do u have to use sudo to become root to change it.</p>
<p dir="auto">don’t use opt in the future</p>
]]></description><link>https://forum.magicmirror.builders/post/80039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80039</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 11:43:00 GMT</pubDate></item></channel></rss>
