<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Monitor says &quot;NO SIGNAL&quot;]]></title><description><![CDATA[<p dir="auto">Hi, so recently I installed MM2 on my RPI with an old Acer X193w monitor which was from 2008.<br />
The problem I have is when I disconnect my HDMI cable from RPI the monitor does not connect to any other input devices which it used to before. If I connect my laptop or any other HDMI output device, it just doesn’t accept any signal from those but only RPI works with Magic mirror working on it as well.<br />
Please help me as I am fairly noob in here.<br />
also, English not being my first language there might be few mistakes.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13446/monitor-says-no-signal</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 10:48:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13446.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Aug 2020 13:27:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Sun, 25 Apr 2021 12:18:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Is your problem is solved?</p>
<p dir="auto">Recently, I am also facing the same issue, I tried to contact the customer care service of the monitor.</p>
<p dir="auto">Later I released, I am using the outdated drivers and hence it is creating the issues to display the pictures. I think you have the same  scenario.  I am linking to the <a href="https://thebestmonitors.com/monitor-randomly-goes-black/" target="_blank" rel="noopener noreferrer nofollow ugc">resource</a>, you can check them for step by step troubleshoot.</p>
<p dir="auto">Thanks,<br />
Jeffer James</p>
]]></description><link>https://forum.magicmirror.builders/post/91041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91041</guid><dc:creator><![CDATA[Jefferjames87]]></dc:creator><pubDate>Sun, 25 Apr 2021 12:18:45 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:40:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> well, thank you for the time I appreciate it. and hope you find a solution in future for this.</p>
]]></description><link>https://forum.magicmirror.builders/post/80060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80060</guid><dc:creator><![CDATA[Ameyalgudkar]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:40:41 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:30:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameyalgudkar" aria-label="Profile: Ameyalgudkar">@<bdi>Ameyalgudkar</bdi></a> hm… i use dvi/hdmi adapter on one monitor, but again, never seen monitor locked to one system, or signal.</p>
<p dir="auto">now… I HAVE seen one system locked to specific config…</p>
<p dir="auto">I have to power off/on my pi4 if I want the second display to work… only recognized at power on…</p>
]]></description><link>https://forum.magicmirror.builders/post/80058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80058</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:30:28 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:26:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> haha yeah even I am not sure what did I do wrong or where. because the monitor used to work fine everything was working well, but this just happened suddenly. Maybe I will just use this monitor on RPI from now on.<br />
Also, I am using it with a DVI to HDMI cable and to micro HDMI. could it be due to any of those reasons?<br />
and I tried removing the DVI and inserting it back as well but that did not work as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/80055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80055</guid><dc:creator><![CDATA[Ameyalgudkar]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:26:05 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:13:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameyalgudkar" aria-label="Profile: Ameyalgudkar">@<bdi>Ameyalgudkar</bdi></a> wow… never ever seen that before… in 40+ years</p>
]]></description><link>https://forum.magicmirror.builders/post/80054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80054</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:13:16 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:10:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it does not reset I don’t think it does. because I tried the method you mentioned but it didn’t work.</p>
]]></description><link>https://forum.magicmirror.builders/post/80053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80053</guid><dc:creator><![CDATA[Ameyalgudkar]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:10:07 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:08:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameyalgudkar" aria-label="Profile: Ameyalgudkar">@<bdi>Ameyalgudkar</bdi></a> if u unplug monitor from power, does it reset?</p>
]]></description><link>https://forum.magicmirror.builders/post/80052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80052</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:08:21 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:07:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> nope.<br />
But it used to before I installed magic mirror and some modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/80051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80051</guid><dc:creator><![CDATA[Ameyalgudkar]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:05:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameyalgudkar" aria-label="Profile: Ameyalgudkar">@<bdi>Ameyalgudkar</bdi></a> the monitor NEVER works on laptop??</p>
]]></description><link>https://forum.magicmirror.builders/post/80050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80050</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:05:42 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 15:04:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> unplug from laptop<br />
power monitor off<br />
plug on to laptop                         [NO IT DOES NOT]<br />
turn monitor on<br />
does it work??</p>
<p dir="auto">unplug from pi<br />
turn monitor off<br />
plug onto laptop                   NO<br />
does it work</p>
<p dir="auto">in simple term, display only works if the hdmi is connected to pi and getting input from pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/80049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80049</guid><dc:creator><![CDATA[Ameyalgudkar]]></dc:creator><pubDate>Tue, 11 Aug 2020 15:04:03 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 14:50:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameyalgudkar" aria-label="Profile: Ameyalgudkar">@<bdi>Ameyalgudkar</bdi></a> no, you missed my question</p>
<p dir="auto">working on pi,<br />
plug onto laptop, fails</p>
<p dir="auto">unplug from laptop<br />
plug on to laptop<br />
does it work??</p>
plug onto laptop<br />
does it work</p>
]]></description><link>https://forum.magicmirror.builders/post/80048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80048</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 14:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 14:48:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes, it works without any problem if it’s connected to the pi. Only does not display anything saying (no signal) when I connect the same HDMI to a laptop out port.</p>
]]></description><link>https://forum.magicmirror.builders/post/80047</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80047</guid><dc:creator><![CDATA[Ameyalgudkar]]></dc:creator><pubDate>Tue, 11 Aug 2020 14:48:32 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor says &quot;NO SIGNAL&quot; on Tue, 11 Aug 2020 13:34:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameyalgudkar" aria-label="Profile: Ameyalgudkar">@<bdi>Ameyalgudkar</bdi></a> if u turn the monitor off and then back on, does it work after disconnecting from the pi?</p>
<p dir="auto">some monitors remember signal at disconnect.</p>
]]></description><link>https://forum.magicmirror.builders/post/80042</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80042</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2020 13:34:46 GMT</pubDate></item></channel></rss>
