<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM2: Treat Two Monitor as One]]></title><description><![CDATA[<p dir="auto">I’m in the research stage of creating a Magic Mirror. I’m trying to make it relatively large and not spend a few hundred on a TV.<br />
I’d like to see about spanning a display across two monitors.</p>
<p dir="auto">I know this is a feature in the Nvidia control panel, so I know it’s possible on at least Windows. For Nvidia, I think it’s called span surround.</p>
<p dir="auto">Is this something that’s possible on a Raspberry Pi running Raspbian?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/13451/mm2-treat-two-monitor-as-one</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 20:19:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13451.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2020 02:06:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM2: Treat Two Monitor as One on Thu, 13 Aug 2020 12:21:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ll have a look, thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/80130</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80130</guid><dc:creator><![CDATA[isaacbenezra]]></dc:creator><pubDate>Thu, 13 Aug 2020 12:21:53 GMT</pubDate></item><item><title><![CDATA[Reply to MM2: Treat Two Monitor as One on Wed, 12 Aug 2020 03:20:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/isaacbenezra" aria-label="Profile: isaacbenezra">@<bdi>isaacbenezra</bdi></a> I haven’t found anything that works. I’ve tested on multiple machines</p>
<p dir="auto">u can drag/drop to make the image cover both displays. but I haven’t found a way to make it happen automated.</p>
<p dir="auto">u can run multiple instances of mm, one on each display, and make it look like one big display</p>
<p dir="auto">see this recent topic<br />
<a href="https://forum.magicmirror.builders/topic/13431/magic-mirror-with-2-displays?page=1">https://forum.magicmirror.builders/topic/13431/magic-mirror-with-2-displays?page=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80078</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80078</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Aug 2020 03:20:44 GMT</pubDate></item></channel></rss>
