<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Module to display information from a text file on a locally shared folder]]></title><description><![CDATA[<p dir="auto">I am looking for some type of way to display information from a text file that is saved to a local network share.</p>
<p dir="auto">We have six year old twins who are starting second grade. I am looking for a way to have a list of “sight words” (common words they are learning) displayed on the screen where the default newsfeed is at. I could edit the compliments list but I would rather have a module that would pull the words from a text file that is saved to a local network share so that I can update it as needed. The words could rotate after a set time period.</p>
<p dir="auto">Is there any current module that is capable of this? If not, would anyone be willing work on one? I am nto a programmer and have no idea where to even start with creating something like this.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13459/module-to-display-information-from-a-text-file-on-a-locally-shared-folder</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 18:13:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13459.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Aug 2020 19:38:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 01 Nov 2020 08:50:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a><br />
Easy - use the module MMM-GoogleSheets<br />
and edit your own Google Sheet.<br />
That’s exactly how I “communicate” with my mirror from anywhere</p>
]]></description><link>https://forum.magicmirror.builders/post/84140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84140</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Sun, 01 Nov 2020 08:50:17 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Wed, 09 Sep 2020 01:22:53 GMT]]></title><description><![CDATA[<p dir="auto">OK. With some nudging from <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , I was able to get things fixed up. Have the analog clock instead of digital, have a clockface with regular numbers so they can start learning how to tell time, got rid of the newsfeed and moved the compliments to display at the bottom instead of the newsfeed.</p>
<p dir="auto">Next steps is to add more words through a local file and then maybe install a module to pull some pictures from a public feed or maybe some select pictures from my google drive.</p>
<p dir="auto"><img src="/assets/uploads/files/1599614459440-2020.09.08.mm.jpg" alt="2020.09.08.mm.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/81485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81485</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Wed, 09 Sep 2020 01:22:53 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 30 Aug 2020 20:29:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> bug in 2.12  fix described here<br />
<a href="https://forum.magicmirror.builders/topic/13190/no-numbers-in-analog-watch-face/13?page=2">https://forum.magicmirror.builders/topic/13190/no-numbers-in-analog-watch-face/13?page=2</a></p>
<p dir="auto">by MichMich</p>
<p dir="auto">if you used my install script,  I posted a few further down with the steps<br />
<a href="https://forum.magicmirror.builders/topic/13190/no-numbers-in-analog-watch-face/17?page=2">https://forum.magicmirror.builders/topic/13190/no-numbers-in-analog-watch-face/17?page=2</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80951</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 30 Aug 2020 20:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 30 Aug 2020 19:45:31 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Sam! My next task is to change the digital clock to an analog clock. We are also trying to teach the kids how to tell time on an analog clock.</p>
<p dir="auto">I changed displayType: “analog” which put up an analog clock with no numbers (just the circle and hands).</p>
<p dir="auto">I tried to change analogFace: “face-010” but it only showed the hands, no face and no numbers.</p>
<p dir="auto">Did I miss anything? Here is a snip from my clock.js</p>
<pre><code>Module.register("clock", {
	// Module config defaults.
	defaults: {
		displayType: "analog", // options: digital, analog, both
		timeFormat: config.timeFormat,
		displaySeconds: true,
		showPeriod: true,
		showPeriodUpper: false,
		clockBold: false,
		showDate: true,
		showWeek: false,
		dateFormat: "dddd, LL",
		/* specific to the analog clock */
		analogSize: "200px",
		analogFace: "face-010", // options: 'none', 'simple', 'face-###' (where ### is 001 to 012 inclusive)
<p dir="auto">Here is how it looks with the simple analog clock.<br />
<img src="/assets/uploads/files/1598816675246-mm-analog.png" alt="mm analog.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/80949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80949</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Sun, 30 Aug 2020 19:45:31 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 30 Aug 2020 18:02:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> no. just interested… good work</p>
]]></description><link>https://forum.magicmirror.builders/post/80947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80947</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 30 Aug 2020 18:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 30 Aug 2020 17:46:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Right now the file is on the pi. This has been on hold since I originally posted as other things came up.</p>
]]></description><link>https://forum.magicmirror.builders/post/80946</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80946</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Sun, 30 Aug 2020 17:46:16 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 30 Aug 2020 13:48:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> cool, thx for the feedback</p>
<p dir="auto">is the file on the.pi, or on a server like u had originally wanted?</p>
]]></description><link>https://forum.magicmirror.builders/post/80944</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80944</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 30 Aug 2020 13:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Sun, 30 Aug 2020 13:43:52 GMT]]></title><description><![CDATA[<p dir="auto">OK. Just an update. Finally got back to this. Have it installed and mounted. Kids like it!</p>
<p dir="auto"><img src="/assets/uploads/files/1598795021927-20200830_0933051.jpg" alt="20200830_0933051.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/80943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80943</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Sun, 30 Aug 2020 13:43:52 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Fri, 14 Aug 2020 02:41:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> the ln command ‘creates’ the local file.<br />
and the file can contain just words in each of the time slots.</p>
<p dir="auto">make it work with an actual file, and then see if that is what u want. if so, then you can move the real file to the server. mount the drive into the pi, and then link the local file to the server file</p>
]]></description><link>https://forum.magicmirror.builders/post/80159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80159</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Aug 2020 02:41:50 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Fri, 14 Aug 2020 02:07:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/80150">Module to display information from a text file on a locally shared folder</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> see the ln command for link</p>
<p dir="auto">the compliments file MUST be in the compliments folder or subfolder. it cannot just be anywhere</p>
<p dir="auto">the module config entry is</p>
<pre><code>remoteFile: 'my_comp.json',
<p dir="auto">so, you could make a link like this</p>
<pre><code>ln -s my_comp.json /mount_location/path/filename.xxx
<p dir="auto">that means make a file entry in the current folder called my_comp.json<br />
and map it to the mounted file <a href="http://filename.xxx" target="_blank" rel="noopener noreferrer nofollow ugc">filename.xxx</a></p>
<p dir="auto">i use this approach for linking pictures from my file server to be shown by the  MMM-ImagesPhotos module</p>
<p dir="auto">I have not tried any of this yet (have not had the time yet) but trying to make sure I understand.<br />
If I created the word list file called “wordlist.txt”, saved that file to a share of “\server\share\wordlist.txt”.<br />
I would create a file named “my_comp.json” in the compliments folder.<br />
Then link it to the text file with</p>
<pre><code>ln -s my_comp.json /server/share/wordlist.txt
<p dir="auto">And the wordlist.txt would look something like this.</p>
<pre><code>{
    "anytime" : [
        "Band",
        "Firetruck",
        "Movie",
    "morning" : [
        "Good morning, sunshine!",
    "afternoon" : [
        "Hitting your stride!",
    "evening" : [
        "See you tomorrow!",
<p dir="auto">Or would it be easier all around to just set the “remotefile:” and save it locally on the pi. I will be connecting to the pi over vnc.</p>
]]></description><link>https://forum.magicmirror.builders/post/80156</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80156</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Fri, 14 Aug 2020 02:07:34 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Thu, 13 Aug 2020 21:14:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> see the ln command for link</p>
]]></description><link>https://forum.magicmirror.builders/post/80150</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80150</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Aug 2020 21:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Thu, 13 Aug 2020 20:57:52 GMT]]></title><description><![CDATA[<p dir="auto">Sam,<br />
Thanks for the reply! I will have to read up on configuring that module then and figure out how to link to a file. Reading it only on startup is alright as I could restart daily or weekly.</p>
]]></description><link>https://forum.magicmirror.builders/post/80149</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80149</guid><dc:creator><![CDATA[TomBrown]]></dc:creator><pubDate>Thu, 13 Aug 2020 20:57:52 GMT</pubDate></item><item><title><![CDATA[Reply to Module to display information from a text file on a locally shared folder on Thu, 13 Aug 2020 19:51:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tombrown" aria-label="Profile: TomBrown">@<bdi>TomBrown</bdi></a> compliments can read from a file, and u can link that file to be on a file server.</p>
<p dir="auto">and u can run two instances of compliments showing  different info.</p>
<p dir="auto">only issue is that it reads the file only on startup.</p>
]]></description><link>https://forum.magicmirror.builders/post/80147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80147</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Aug 2020 19:51:24 GMT</pubDate></item></channel></rss>
