<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Displaying Remotely on Two Tablets (How to run separate instances?)]]></title><description><![CDATA[<p dir="auto">I am trying to create a MagicMirror using multiple tablets that VNC into a single Pi running multiple instances of MagicMirror. I have copied the main folder, and I am able to VNC into multiple virtual desktops running multiple instances, but it always uses the config.js file from the main MagicMirror folder. How can I have two different configs running at the same time? That way I can have, say, weather on one display and news on another. Is this possible? I am guessing it has something to do with changing the path of the config file it launches with, but I am not sure how to do that.</p>
<p dir="auto">Thanks for such an awesome platform!</p>
]]></description><link>https://forum.magicmirror.builders/topic/1347/displaying-remotely-on-two-tablets-how-to-run-separate-instances</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 20:33:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1347.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jan 2017 02:36:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Displaying Remotely on Two Tablets (How to run separate instances?) on Wed, 08 Nov 2017 13:08:39 GMT]]></title><description><![CDATA[<p dir="auto">@Sean thanks for that description. I will probably take the same approach. Currently I am planning to provide a friend with an own display and I am not yet decided if the RPI should remotely access the server instance (via VPN client) or if I would have the application running locally on the RPI and just fetch the content from my network.</p>
]]></description><link>https://forum.magicmirror.builders/post/30864</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30864</guid><dc:creator><![CDATA[mmmmh]]></dc:creator><pubDate>Wed, 08 Nov 2017 13:08:39 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying Remotely on Two Tablets (How to run separate instances?) on Tue, 07 Nov 2017 14:26:17 GMT]]></title><description><![CDATA[<p dir="auto">I’ve tried and got success.<br />
<img src="/assets/uploads/files/1510064573151-mm.jpg" alt="0_1510064572344_MM.jpg" class=" img-fluid img-markdown" /><br />
Just copy your <code>MagicMirror</code> directory to <code>MagicMirror2</code>.<br />
Modify each config(especially give different port no.)<br />
And execute each <code>node serveronly</code> and open them remotely.<br />
(I didn’t test this remotely, but there is no reason not working)</p>
]]></description><link>https://forum.magicmirror.builders/post/30833</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30833</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 07 Nov 2017 14:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying Remotely on Two Tablets (How to run separate instances?) on Tue, 07 Nov 2017 12:28:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aezothe" aria-label="Profile: Aezothe">@<bdi>Aezothe</bdi></a> That would be awesome… I know someone else who did but never posted how here… it would be great if you could post how you did it :)  Others really want to know!</p>
]]></description><link>https://forum.magicmirror.builders/post/30831</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30831</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 07 Nov 2017 12:28:15 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying Remotely on Two Tablets (How to run separate instances?) on Tue, 07 Nov 2017 10:46:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aezothe" aria-label="Profile: Aezothe">@<bdi>Aezothe</bdi></a> I would also like to run separate instances. How did you do it?</p>
]]></description><link>https://forum.magicmirror.builders/post/30826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30826</guid><dc:creator><![CDATA[mmmmh]]></dc:creator><pubDate>Tue, 07 Nov 2017 10:46:07 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying Remotely on Two Tablets (How to run separate instances?) on Fri, 06 Jan 2017 02:58:23 GMT]]></title><description><![CDATA[<p dir="auto">Never mind. Finally figured it out. I was trying to use the DailyXKCD module, and it was somehow failing. But in case anyone was curious, you can do this, and it works out pretty well. Will eventually post the finished project.</p>
]]></description><link>https://forum.magicmirror.builders/post/10501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10501</guid><dc:creator><![CDATA[Aezothe]]></dc:creator><pubDate>Fri, 06 Jan 2017 02:58:23 GMT</pubDate></item></channel></rss>
