<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Face-Reco-DNN]]></title><description><![CDATA[<p dir="auto">I was configuration MMM-Face-Reco-DNN module   but i can not data train or photo set , can any one help me to make a video tutorial  to config MMM-Face-Reco-DNN.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13478/mmm-face-reco-dnn</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:18:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13478.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Aug 2020 16:32:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Mon, 17 Apr 2023 19:00:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
you have been right, it seems, taht the pictures were too big. i shrink them and it worked</p>
]]></description><link>https://forum.magicmirror.builders/post/108934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108934</guid><dc:creator><![CDATA[Seregeth]]></dc:creator><pubDate>Mon, 17 Apr 2023 19:00:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Mon, 17 Apr 2023 18:43:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Maybe, but i took the images the same way like the first ones.<br />
I will try to edit the fotos an will run again</p>
]]></description><link>https://forum.magicmirror.builders/post/108935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108935</guid><dc:creator><![CDATA[Seregeth]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Mon, 17 Apr 2023 18:38:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/seregeth" aria-label="Profile: Seregeth">@<bdi>Seregeth</bdi></a> the images are not the right quality or size?</p>
]]></description><link>https://forum.magicmirror.builders/post/108931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108931</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:38:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Mon, 17 Apr 2023 18:28:07 GMT]]></title><description><![CDATA[<p dir="auto">I have now managed to get the module to recognise me. Following this nice success, I now wanted to add other people to it.</p>
<p dir="auto">But that is no longer possible, the process always stops:</p>
<p dir="auto">I start:<br />
python3 <a href="http://encode.py" target="_blank" rel="noopener noreferrer nofollow ugc">encode.py</a> -i …/dataset/ -e encodings.pickle -d hog</p>
<p dir="auto">then comes:<br />
[INFO] quantifyng faces…<br />
[INFO] processing image 1/17 - …/dataset/Pauline/img01.jpg<br />
Killed</p>
<p dir="auto">I then tried deleting the first image (img01.jpg) once and trying again. It worked better then, but it still broke. This time, image img01.jpg came first, then image img04.jpg, then Killed.</p>
<p dir="auto">What could be the reason that the process is no longer executed?</p>
]]></description><link>https://forum.magicmirror.builders/post/108930</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108930</guid><dc:creator><![CDATA[Seregeth]]></dc:creator><pubDate>Mon, 17 Apr 2023 18:28:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Fri, 07 Apr 2023 22:20:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/seregeth" aria-label="Profile: Seregeth">@<bdi>Seregeth</bdi></a> I think you posted this to the wrong topic</p>
<p dir="auto">has nothing to do with face reco</p>
]]></description><link>https://forum.magicmirror.builders/post/108714</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108714</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 07 Apr 2023 22:20:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Wed, 05 Apr 2023 15:29:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/seregeth" aria-label="Profile: Seregeth">@<bdi>Seregeth</bdi></a> the module hasn’t been supported for a number of years,  and I don’t remember any debugging assistance provided</p>
]]></description><link>https://forum.magicmirror.builders/post/108681</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108681</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Apr 2023 15:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Wed, 05 Apr 2023 15:26:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you very much for the feedback.</p>
<p dir="auto">I almost thought so. But maybe someone knows, so I can narrow down where my mistake is.</p>
<p dir="auto">If it’s because the person isn’t recognised, it’s different than if I’ve set a parameter incorrectly.</p>
]]></description><link>https://forum.magicmirror.builders/post/108680</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108680</guid><dc:creator><![CDATA[Seregeth]]></dc:creator><pubDate>Wed, 05 Apr 2023 15:26:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Wed, 05 Apr 2023 15:21:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/seregeth" aria-label="Profile: Seregeth">@<bdi>Seregeth</bdi></a> I do not know. this would have to be provided by the OCV (Open computer vision)<br />
code, not ours</p>
]]></description><link>https://forum.magicmirror.builders/post/108679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108679</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Apr 2023 15:21:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Wed, 05 Apr 2023 15:01:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
i have  done all to import my fotos. i worked all along without any error.<br />
is it possible to test the importet Foto set?<br />
As i set up the Module, i will not recognice me. Is it possible to test anyway?</p>
]]></description><link>https://forum.magicmirror.builders/post/108678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108678</guid><dc:creator><![CDATA[Seregeth]]></dc:creator><pubDate>Wed, 05 Apr 2023 15:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Sun, 23 Aug 2020 02:13:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parvez" aria-label="Profile: Parvez">@<bdi>Parvez</bdi></a> hi,</p>
<p dir="auto">I took a fork of SMAI that uses recoDNN an doesn’t require any external python running (recoDNN does that), i also detail training.</p>
<p dir="auto"><a href="https://github.com/jimbydude/MMM-AI-Face-Login" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jimbydude/MMM-AI-Face-Login</a></p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/80596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80596</guid><dc:creator><![CDATA[jimbydude]]></dc:creator><pubDate>Sun, 23 Aug 2020 02:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 18:13:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Thank you for your help…</p>
]]></description><link>https://forum.magicmirror.builders/post/80293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80293</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 18:13:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 18:11:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parvez" aria-label="Profile: Parvez">@<bdi>Parvez</bdi></a> sorry, no idea…</p>
]]></description><link>https://forum.magicmirror.builders/post/80292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80292</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 18:11:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 18:07:28 GMT]]></title><description><![CDATA[<p dir="auto">i can’t solve it</p>
]]></description><link>https://forum.magicmirror.builders/post/80289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80289</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 18:07:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok i will download  open cv3</p>
]]></description><link>https://forum.magicmirror.builders/post/80285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80285</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:55:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parvez" aria-label="Profile: Parvez">@<bdi>Parvez</bdi></a>  dist-packages/cv2  seems pretty old… cv3 is current, cv4 is also out…</p>
]]></description><link>https://forum.magicmirror.builders/post/80284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80284</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:55:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:40:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parvez" aria-label="Profile: Parvez">@<bdi>Parvez</bdi></a>  looks like it is trying to detect text in the images… don’t know why</p>
<p dir="auto"><a href="https://raspberrypi.stackexchange.com/questions/89231/tesseract-ocr-4-x-beta-for-raspberry-pi" target="_blank" rel="noopener noreferrer nofollow ugc">https://raspberrypi.stackexchange.com/questions/89231/tesseract-ocr-4-x-beta-for-raspberry-pi</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80283</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:40:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:29:57 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1597771793524-sssss.png" alt="sssss.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/80282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80282</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:29:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:27:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parvez" aria-label="Profile: Parvez">@<bdi>Parvez</bdi></a></p>
<pre><code>you will find a script called encode.py in folder tools of the module
<p dir="auto">so,</p>
<pre><code>cd tools
]]></description><link>https://forum.magicmirror.builders/post/80281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80281</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:27:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:26:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/80278">MMM-Face-Reco-DNN</a>:</p>
<p dir="auto">python3 <a href="http://encode.py" target="_blank" rel="noopener noreferrer nofollow ugc">encode.py</a> -i …/dataset/ -e encodings.pickle -d hog</p>
<p dir="auto">how to run this script<br />
<img src="/assets/uploads/files/1597771579888-ss.png" alt="ss.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/80280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80280</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:22:39 GMT]]></title><description><![CDATA[<p dir="auto">if any one make a vedio for me is very  helpful . i will submit this project my university</p>
]]></description><link>https://forum.magicmirror.builders/post/80279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80279</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:22:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 17:16:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parvez" aria-label="Profile: Parvez">@<bdi>Parvez</bdi></a> what happens when u run the script?</p>
<pre><code>Facial Recognition Embeddings
After you set up your dataset, we need to go to the embeddings for the recognitions. I prepared a script for that. It took a while to run on my Macbook and will take much longer on a Raspberry Pi, so if possible, use it on a computer with more power and then transfer the resulting file.
You will find a script called encode.py in folder tools of the module. The following arguments are default:
python3 encode.py -i ../dataset/ -e encodings.pickle -d hog
<p dir="auto">linux us case sensitive… so Parvez is not the same as parvez</p>
]]></description><link>https://forum.magicmirror.builders/post/80278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80278</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 17:16:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 16:55:17 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1597769716091-capture.png" alt="Capture.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/80275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80275</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 16:55:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Face-Reco-DNN on Tue, 18 Aug 2020 16:53:14 GMT]]></title><description><![CDATA[<p dir="auto">but its do not work.</p>
]]></description><link>https://forum.magicmirror.builders/post/80274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80274</guid><dc:creator><![CDATA[Parvez]]></dc:creator><pubDate>Tue, 18 Aug 2020 16:53:14 GMT</pubDate></item></channel></rss>
