<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Second Calendar is offset&#x2F; Indented]]></title><description><![CDATA[<p dir="auto">Hello, I have two calendars.  The second one is indented from the first.  The .js looks the same so I’m not sure what to fix.  Looking for suggestions.  The OCD is strong! :pile_of_poo:</p>
<p dir="auto">The indent:<br />
<img src="/assets/uploads/files/1597775271577-mm_cal_indent.png" alt="mm_cal_indent.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Code:<br />
<img src="/assets/uploads/files/1597775452940-mm_cal_indent_code.png" alt="mm_cal_indent_code.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/13480/second-calendar-is-offset-indented</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 11:32:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13480.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Aug 2020 18:35:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Second Calendar is offset&#x2F; Indented on Thu, 17 Jun 2021 10:48:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone, I have the same issue as <a class="plugin-mentions-user plugin-mentions-a" href="/user/spoonek" aria-label="Profile: spoonek">@<bdi>spoonek</bdi></a> and don’t have a custom.css yet. It would be awesome to elaborate on potential solutions together! :flexed_biceps:</p>
]]></description><link>https://forum.magicmirror.builders/post/92186</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92186</guid><dc:creator><![CDATA[hclaus]]></dc:creator><pubDate>Thu, 17 Jun 2021 10:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to Second Calendar is offset&#x2F; Indented on Thu, 20 Aug 2020 19:13:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spoonek" aria-label="Profile: spoonek">@<bdi>spoonek</bdi></a>  i duplicated cals like you and don’t see this behavior…</p>
<p dir="auto">can u tell me more about your system? do you have  entries in the css/custom.css?</p>
<p dir="auto">what version is this, do</p>
<pre><code>cd ~/MagicMirror
grep version | package.json
<p dir="auto">I see<br />
grep version  package.json<br />
“version”: “2.12.0”,</p>
]]></description><link>https://forum.magicmirror.builders/post/80430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80430</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 19:13:11 GMT</pubDate></item><item><title><![CDATA[Reply to Second Calendar is offset&#x2F; Indented on Thu, 20 Aug 2020 16:03:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spoonek" aria-label="Profile: spoonek">@<bdi>spoonek</bdi></a> I saw your comment. I do not know a resolution. I remember that others have asked the same question, but don’t remember the solution</p>
]]></description><link>https://forum.magicmirror.builders/post/80415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80415</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 20 Aug 2020 16:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to Second Calendar is offset&#x2F; Indented on Thu, 20 Aug 2020 14:58:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/80297">Second Calendar is offset/ Indented</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spoonek" aria-label="Profile: spoonek">@<bdi>spoonek</bdi></a> i do not know, but if u change the symbol of the second cal to the same as the 1st cal, is the offset still there?</p>
<p dir="auto">It’s still indented.</p>
]]></description><link>https://forum.magicmirror.builders/post/80411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80411</guid><dc:creator><![CDATA[spoonek]]></dc:creator><pubDate>Thu, 20 Aug 2020 14:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Second Calendar is offset&#x2F; Indented on Wed, 19 Aug 2020 13:57:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Good suggestion.  I tried it and same issue though.</p>
]]></description><link>https://forum.magicmirror.builders/post/80324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80324</guid><dc:creator><![CDATA[spoonek]]></dc:creator><pubDate>Wed, 19 Aug 2020 13:57:06 GMT</pubDate></item><item><title><![CDATA[Reply to Second Calendar is offset&#x2F; Indented on Tue, 18 Aug 2020 19:08:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spoonek" aria-label="Profile: spoonek">@<bdi>spoonek</bdi></a> i do not know, but if u change the symbol of the second cal to the same as the 1st cal, is the offset still there?</p>
]]></description><link>https://forum.magicmirror.builders/post/80297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80297</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Aug 2020 19:08:54 GMT</pubDate></item></channel></rss>
