<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IR Touch Frame calibration]]]]]]></title><description><![CDATA[<p dir="auto">I’ve been searching through the hardware portion, but I couldn’t find something that really said that would be great an IR frame, or a touch-file. I was planning to use RPi3, but if I need more power, I’m going to get aboard. Also, I haven’t bought any glass or screen yet, seeing that they might not be compatible.</p>
<p dir="auto">Nonmarketapp agensgp antimalware</p>
]]></description><link>https://forum.magicmirror.builders/topic/13508/ir-touch-frame-calibration</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 07:09:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13508.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Aug 2020 23:21:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IR Touch Frame calibration]]]] on Tue, 25 Aug 2020 05:42:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jimbydude" aria-label="Profile: jimbydude">@<bdi>jimbydude</bdi></a><br />
<em>Update</em><br />
I used this guide to setup calibration:<br />
<a href="https://www.thingsconnected.io/raspberry-pi-7-inch-touch-screen-calibration/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.thingsconnected.io/raspberry-pi-7-inch-touch-screen-calibration/</a></p>
<p dir="auto">Also, despite the manufacturer saying only supports 1 point on Linux, I definitely see multi-point, tried with six fingers using this site:<br />
<a href="https://paveldogreat.github.io/WebGL-Fluid-Simulation/" target="_blank" rel="noopener noreferrer nofollow ugc">https://paveldogreat.github.io/WebGL-Fluid-Simulation/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/80720</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80720</guid><dc:creator><![CDATA[jimbydude]]></dc:creator><pubDate>Tue, 25 Aug 2020 05:42:52 GMT</pubDate></item><item><title><![CDATA[Reply to IR Touch Frame calibration]]]] on Sun, 23 Aug 2020 05:15:14 GMT]]></title><description><![CDATA[<p dir="auto">I got 43 inch IR frame from aliexpress, it took a bit to track down calibration steps. It basically worked out of box just plugging into pi 4.</p>
<p dir="auto">I’m powering directly from pi also, seemed ok.</p>
<p dir="auto">I’m not at home but can add more detail and link to how to calibrate, once back in couple days.</p>
]]></description><link>https://forum.magicmirror.builders/post/80597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80597</guid><dc:creator><![CDATA[jimbydude]]></dc:creator><pubDate>Sun, 23 Aug 2020 05:15:14 GMT</pubDate></item></channel></rss>
