<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot;]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I installed Google Assistant  on windows 10 and pass audio and push to talk test, now I got error at the last step:<br />
<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>: error: argument --credentials: No such file or directory: “/c/Users/myname/AppData/Roaming/google-oauthlib-tool/credentials.json”<br />
I checked this path, I do have credentials.json there.<br />
And I tried to modify this part in MMM-GoogleAssistant/pi/assistant.py,<br />
def init_googleAssistant():<br />
parser = argparse.ArgumentParser(<br />
formatter_class=argparse.RawTextHelpFormatter)<br />
parser.add_argument(‘–credentials’, type=existing_file,<br />
metavar=‘OAUTH2_CREDENTIALS_FILE’,<br />
default=‘/c/Users/vellm/AppData/Roaming/google-oauthlib-tool/credentials.json’,<br />
#default=os.path.join(<br />
#    os.path.expanduser(“~”),    #/AppData/Roaming/google-oauthlib-tool/credentials.json<br />
#   ‘google-oauthlib-tool’,<br />
#   ‘credentials.json’<br />
#),<br />
help=‘Path to store and read OAuth2 credentials’)<br />
I think the issue happened in this line, but I cannot solve it:<br />
default=‘/c/Users/vellm/AppData/Roaming/google-oauthlib-tool/credentials.json’,</p>
<p dir="auto">Anyone can tell me how to solve it?<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/13521/install-mmm-googleassistant-on-windows-error-argument-credentials-no-such-file-or-directory-credentials-json</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 23:04:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13521.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Aug 2020 00:01:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 20:08:40 GMT]]></title><description><![CDATA[<p dir="auto">never try</p>
]]></description><link>https://forum.magicmirror.builders/post/80756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80756</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 25 Aug 2020 20:08:40 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 20:07:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> will MagicMirror in docker container work?</p>
]]></description><link>https://forum.magicmirror.builders/post/80755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80755</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Aug 2020 20:07:51 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 20:01:57 GMT]]></title><description><![CDATA[<p dir="auto">best way for using MagicMirror and <code>complex</code> module under windows is virtualization of a linux debian machine</p>
<ul>
<li><a href="https://www.virtualbox.org/" target="_blank" rel="noopener noreferrer nofollow ugc">virtualbox</a></li>
<li>download linux debian and install it in virtualbox</li>
<li>install magicmirror and modules :)</li>
</ul>
<p dir="auto">result:</p>
<ul>
<li>full emulation of linux machine</li>
<li>all package is compatible with debian because rapsbian Os is make is a modified debian version</li>
<li>snowboy works (but not sure this wersion of this module works… because google make a lot of library update)</li>
</ul>
<p dir="auto">at begining, i have coded with this method ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/80754</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80754</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 25 Aug 2020 20:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 18:19:17 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your reply!</p>
]]></description><link>https://forum.magicmirror.builders/post/80746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80746</guid><dc:creator><![CDATA[vivian0239]]></dc:creator><pubDate>Tue, 25 Aug 2020 18:19:17 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 16:22:55 GMT]]></title><description><![CDATA[<p dir="auto">snowboy CAN works in windows but with a LOT of modifications and still very too complex</p>
<p dir="auto">so i prefer say this: actually there is no way to work under windows environement</p>
]]></description><link>https://forum.magicmirror.builders/post/80742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80742</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 25 Aug 2020 16:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 16:18:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vivian0239" aria-label="Profile: vivian0239">@<bdi>vivian0239</bdi></a>  I am sure <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a>  will clarify</p>
]]></description><link>https://forum.magicmirror.builders/post/80741</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80741</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Aug 2020 16:18:12 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 15:35:12 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your reply! It’s really bad news.</p>
]]></description><link>https://forum.magicmirror.builders/post/80734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80734</guid><dc:creator><![CDATA[vivian0239]]></dc:creator><pubDate>Tue, 25 Aug 2020 15:35:12 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 00:22:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vivian0239" aria-label="Profile: vivian0239">@<bdi>vivian0239</bdi></a> I don’t think he has tested on windows.</p>
<p dir="auto">I suspect the voice reco tool, snowboy, still does not work on windows</p>
]]></description><link>https://forum.magicmirror.builders/post/80706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80706</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 25 Aug 2020 00:22:01 GMT</pubDate></item><item><title><![CDATA[Reply to Install MMM-GoogleAssistant  on windows,  error: argument --credentials: No such file or directory: &quot;***credentials.json&quot; on Tue, 25 Aug 2020 00:17:52 GMT]]></title><description><![CDATA[<p dir="auto">I change this to :<br />
default=‘C:\Users\myname\AppData\Roaming\google-oauthlib-tool\credentials.json’,</p>
<p dir="auto">And another issue appeared:<br />
$ /c/Users/myname/env/Scripts/python -u <a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a><br />
pubnub subscription completed<br />
Traceback (most recent call last):<br />
File “<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>”, line 140, in <br />
main()<br />
File “<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>”, line 137, in main<br />
init_googleAssistant()<br />
File “<a href="http://assistant.py" target="_blank" rel="noopener noreferrer nofollow ugc">assistant.py</a>”, line 131, in init_googleAssistant<br />
with Assistant(credentials,“<a href="http://873445380749-it4rg69bo0sbrqg69upkorp79m6mbq0d.apps.googleusercontent.com" target="_blank" rel="noopener noreferrer nofollow ugc">873445380749-it4rg69bo0sbrqg69upkorp79m6mbq0d.apps.googleusercontent.com</a>”) as assistant:<br />
File “C:\Users\myname\env\lib\site-packages\google\assistant\library\assistant.py”, line 90, in <strong>init</strong><br />
self._load_lib()<br />
File “C:\Users\myname\env\lib\site-packages\google\assistant\library\assistant.py”, line 270, in _load_lib<br />
self.<em>lib = cdll.LoadLibrary(lib_path)<br />
File "c:\python38\lib\ctypes_<em>init</em></em>.py", line 451, in LoadLibrary<br />
return self.<em>dlltype(name)<br />
File "c:\python38\lib\ctypes_<em>init</em></em>.py", line 373, in <strong>init</strong><br />
self._handle = _dlopen(self._name, mode)<br />
OSError: [WinError 193] %1 is not a valid Win32 application<br />
hello from python!!</p>
]]></description><link>https://forum.magicmirror.builders/post/80705</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/80705</guid><dc:creator><![CDATA[vivian0239]]></dc:creator><pubDate>Tue, 25 Aug 2020 00:17:52 GMT</pubDate></item></channel></rss>
