<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM emulator?]]></title><description><![CDATA[<p dir="auto">Hi there, it there any Magic-Mirror emulator that can simulate my developing MM-modules? I would prefer to develop the code on Windows-based before actually running it on the MagicMirror environment. Or, how you guys develop the modules if you are new to MM like me?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13571/mm-emulator</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 06:41:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13571.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Sep 2020 08:52:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM emulator? on Wed, 02 Sep 2020 12:32:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leoliao1980" aria-label="Profile: leoliao1980">@<bdi>leoliao1980</bdi></a> also, the process is the same.<br />
you don’t edit IN  mm, you edit the files used, then launch mm.</p>
<p dir="auto">you can do that in windows, as long as I don’t need access to any pi hardware.</p>
<p dir="auto">install process<br />
git clone like normal<br />
cd MagicMirror<br />
npm install<br />
cd …\fonts<br />
npm install<br />
cd …\vendor<br />
npm install<br />
cd …<br />
npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/81126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81126</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Sep 2020 12:32:26 GMT</pubDate></item><item><title><![CDATA[Reply to MM emulator? on Wed, 02 Sep 2020 12:15:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leoliao1980" aria-label="Profile: leoliao1980">@<bdi>leoliao1980</bdi></a> install winscp or bitvise ssh client on your pc,</p>
<p dir="auto">then you can double click edit files on your pi, start and stop mm from  the ssh window</p>
<p dir="auto">and use your browser to see the mm page ( w address:“0.0.0.0”, and ipWhitelist:[]<br />
set in the pi mm config.js</p>
<p dir="auto">it’s the best of both worlds</p>
]]></description><link>https://forum.magicmirror.builders/post/81125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81125</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Sep 2020 12:15:52 GMT</pubDate></item><item><title><![CDATA[Reply to MM emulator? on Wed, 02 Sep 2020 10:59:10 GMT]]></title><description><![CDATA[<p dir="auto">@hango with Windows based,it’s very very limited.<br />
complex module will not works (sample any module with voice [assistant])</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: Cr4z33">@<bdi>Cr4z33</bdi></a> idea is really an alternative ;)</p>
<p dir="auto">Note:  Raspbian is a debian version made for RPI</p>
]]></description><link>https://forum.magicmirror.builders/post/81121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81121</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 02 Sep 2020 10:59:10 GMT</pubDate></item><item><title><![CDATA[Reply to MM emulator? on Wed, 02 Sep 2020 09:25:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leoliao1980" aria-label="Profile: leoliao1980">@<bdi>leoliao1980</bdi></a> either a VM with Debian or a dedicated (Debian) partition looks already fine to me.</p>
]]></description><link>https://forum.magicmirror.builders/post/81118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81118</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Wed, 02 Sep 2020 09:25:36 GMT</pubDate></item></channel></rss>
