<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MyStandings stops]]></title><description><![CDATA[<p dir="auto">After an indeterminate period if time ( hours, days??), the MMM-MyStandings module either stops or just disappears from the screen. I don’t know exactly when it happens but haven’t found any related messages written to the console log. Does anyone have thoughts on how to catch if errors are being issued?  Also is there a way to restart a single module without restarting everything ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13586/mmm-mystandings-stops</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 13:29:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13586.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Sep 2020 23:29:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MyStandings stops on Tue, 20 Dec 2022 20:35:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattkab" aria-label="Profile: mattkab">@<bdi>mattkab</bdi></a> correct. it doesn’t reply , so the front end is waiting.  it checks the loaded status, and waits til that happens  which will never occur.</p>
<p dir="auto">the node helper could log the status( it’s not 200) and any error reported in the API callback.  to help w this debugging.</p>
<p dir="auto">most of the modules have limited to no error recovery</p>
]]></description><link>https://forum.magicmirror.builders/post/106676</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106676</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 20 Dec 2022 20:35:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Tue, 20 Dec 2022 20:23:48 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! I do see that error. I’ve added a ton more logging information to my local instance, and have restarted MM.   If it happens again I’ll have more data to go by.</p>
<p dir="auto">When it hits that condition, it doesn’t send a notification, so that probably breaks the timer interval, though I’m not seeing yet how that happens.  I’ll continue to debug.</p>
]]></description><link>https://forum.magicmirror.builders/post/106675</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106675</guid><dc:creator><![CDATA[mattkab]]></dc:creator><pubDate>Tue, 20 Dec 2022 20:23:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Tue, 20 Dec 2022 20:06:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattkab" aria-label="Profile: mattkab">@<bdi>mattkab</bdi></a> if you look in the mm console output, from npm start</p>
<p dir="auto">you should see a message</p>
<p dir="auto">console.log(“MMM-MyStandings : Could not load data.”);</p>
<p dir="auto">once this happens it never recovers.</p>
<p dir="auto">the message doesn’t provide any info on the cause.</p>
<p dir="auto">if you use pm2 <a href="http://to.launch.mm" target="_blank" rel="noopener noreferrer nofollow ugc">to.launch.mm</a>, the the messages are in the pm2 logs</p>
<p dir="auto">pm2 logs --lines=nnn</p>
<p dir="auto">nnn is some number default 15</p>
]]></description><link>https://forum.magicmirror.builders/post/106674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106674</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 20 Dec 2022 20:06:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Tue, 20 Dec 2022 18:53:26 GMT]]></title><description><![CDATA[<p dir="auto">Sorry to necropost to a 2 year old thread.</p>
<p dir="auto">But I’m seeing the same issue, on the same module. Anyone know why this happens?</p>
<p dir="auto">I have confirmed that it’s making the <a href="http://site.web.api.espn.com/apis/v2/sports/football/nfl/standings?level=3&amp;sort=winpercent:desc,playoffseed:asc" target="_blank" rel="noopener noreferrer nofollow ugc">proper requests to the API</a>, and the API is responding with a valid JSON object.</p>
<p dir="auto">If I restart MM, the standings show up again, but after some period of time, it just disappears.  I do use MMM-Carousel to create slides.</p>
<p dir="auto">I’ll continue to debug.</p>
]]></description><link>https://forum.magicmirror.builders/post/106673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/106673</guid><dc:creator><![CDATA[mattkab]]></dc:creator><pubDate>Tue, 20 Dec 2022 18:53:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Sat, 05 Sep 2020 20:29:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> No joy. No errors being posted for mystandings. I am using facial reco as well. And I see messages showing when mystandings (and myscores) indicating the module being hidden, suspended, and resumed according to the personna set in the config file. The same messages are being posted for the myscores module using the same personna definitions which works just fine. But mystands doesn’t appear to be resuming (or unhidden?) on the screen like it should.</p>
]]></description><link>https://forum.magicmirror.builders/post/81354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81354</guid><dc:creator><![CDATA[ghiesseldorf]]></dc:creator><pubDate>Sat, 05 Sep 2020 20:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Fri, 04 Sep 2020 01:22:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ghiesseldorf" aria-label="Profile: ghiesseldorf">@<bdi>ghiesseldorf</bdi></a> if u filter, it will be a lot longer til it wraps</p>
]]></description><link>https://forum.magicmirror.builders/post/81253</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81253</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 04 Sep 2020 01:22:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Fri, 04 Sep 2020 00:17:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> my console log captures 12 hours before it wraps, but no errors are present when I notice the module has stopped. If it stopped within this timeframe I’ve not found errors.</p>
]]></description><link>https://forum.magicmirror.builders/post/81251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81251</guid><dc:creator><![CDATA[ghiesseldorf]]></dc:creator><pubDate>Fri, 04 Sep 2020 00:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyStandings stops on Thu, 03 Sep 2020 23:38:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ghiesseldorf" aria-label="Profile: ghiesseldorf">@<bdi>ghiesseldorf</bdi></a> open the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors,  usually red text.</p>
<p dir="auto">you can also filter by module, by placing  part of the module name in the filter field, like stand</p>
]]></description><link>https://forum.magicmirror.builders/post/81250</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81250</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Sep 2020 23:38:32 GMT</pubDate></item></channel></rss>
