<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[iFrame and daily changing url ...]]></title><description><![CDATA[<p dir="auto">Hello MM-Fans,<br />
I would like to bring the content of a website (my children’s school timetable) to my mirror via iFrame. Basically no problem, but the page requires</p>
<ul>
<li>a registration (user / password)</li>
<li>a mouse click on an image</li>
<li>until I come to a URL that changes daily and which I can display via iFrame.</li>
</ul>
<p dir="auto">Has one of you already solved such a problem?<br />
I would be happy about every idea.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13588/iframe-and-daily-changing-url</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 02:09:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13588.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Sep 2020 08:11:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to iFrame and daily changing url ... on Sun, 20 Sep 2020 17:37:33 GMT]]></title><description><![CDATA[<p dir="auto">I would inspect the network traffic and try to reproduce it on the node backend.</p>
]]></description><link>https://forum.magicmirror.builders/post/82102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82102</guid><dc:creator><![CDATA[Jalibu]]></dc:creator><pubDate>Sun, 20 Sep 2020 17:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to iFrame and daily changing url ... on Fri, 18 Sep 2020 13:21:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mymirror" aria-label="Profile: MyMirror">@<bdi>MyMirror</bdi></a> so, it would take some programming and investigation</p>
<p dir="auto">investigation is using the developers window on those pages to see if there is any ID or layout u can find to locate the button/column elements to send a click to</p>
<p dir="auto">then programming wise you can get to the doc in the iframe and send the clicks</p>
<p dir="auto"><a href="https://www.dyn-web.com/tutorials/iframes/refs/iframe.php" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dyn-web.com/tutorials/iframes/refs/iframe.php</a></p>
]]></description><link>https://forum.magicmirror.builders/post/81977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81977</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Sep 2020 13:21:02 GMT</pubDate></item><item><title><![CDATA[Reply to iFrame and daily changing url ... on Fri, 18 Sep 2020 06:35:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jalibu" aria-label="Profile: Jalibu">@<bdi>Jalibu</bdi></a><br />
Thanks for your reply.<br />
I just can give the url …<br />
<a href="https://www.dsbmobile.de" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dsbmobile.de</a></p>
<p dir="auto">My Problem:<br />
The normal use is to login with user/passwort.<br />
After the login it looks like that:<br />
<img src="/assets/uploads/files/1600410851724-a5f1b485-62c3-4bcc-a586-e9fc380e4801-grafik.png" alt="a5f1b485-62c3-4bcc-a586-e9fc380e4801-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">On this page i have to click on the plan to get the larger version (cutout):<br />
<img src="/assets/uploads/files/1600409708040-01051f2b-0c85-46aa-831e-aa4c2f837196-grafik-resized.png" alt="01051f2b-0c85-46aa-831e-aa4c2f837196-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">On the right side is a button to get a side for the MM.<br />
See the url …<br />
<img src="/assets/uploads/files/1600410140926-7ae980a2-29b6-4510-8fb8-8c67ec666b7f-grafik-resized.png" alt="7ae980a2-29b6-4510-8fb8-8c67ec666b7f-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Another problem: On this site, there is information for 2 days. To switch between the days, i have to klick the “&lt;” or “&gt;” on the upper left hand site.</p>
<p dir="auto">So the main problem is to get the “<a href="https://app.dsbcontrol.de/data/5480ecb0-656c-4da8-be59-e50e376a97aa/eadd132b" target="_blank" rel="noopener noreferrer nofollow ugc">https://app.dsbcontrol.de/data/5480ecb0-656c-4da8-be59-e50e376a97aa/eadd132b</a> …” every day and how to pass this changing url every day to the iFrame module. If i use this url, i didn’t have to use a user/passwort.</p>
<p dir="auto">The second problem is to get the information for the right day … (“&lt;” or “&gt;”)</p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/post/81970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81970</guid><dc:creator><![CDATA[MyMirror]]></dc:creator><pubDate>Fri, 18 Sep 2020 06:35:51 GMT</pubDate></item><item><title><![CDATA[Reply to iFrame and daily changing url ... on Thu, 17 Sep 2020 16:24:34 GMT]]></title><description><![CDATA[<p dir="auto">it depends on how the “user / passwort” and the required mouse click is implemented and what it actually does…<br />
Without more details it is hard to give you an answer here.</p>
<p dir="auto">In the worst case you could use a scripted headless chrome in the background that logs in, clicks the image and takes a screenshot of the page ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/81943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81943</guid><dc:creator><![CDATA[Jalibu]]></dc:creator><pubDate>Thu, 17 Sep 2020 16:24:34 GMT</pubDate></item><item><title><![CDATA[Reply to iFrame and daily changing url ... on Wed, 16 Sep 2020 04:26:31 GMT]]></title><description><![CDATA[<p dir="auto">is there possibly a workaround with python?</p>
]]></description><link>https://forum.magicmirror.builders/post/81850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81850</guid><dc:creator><![CDATA[MyMirror]]></dc:creator><pubDate>Wed, 16 Sep 2020 04:26:31 GMT</pubDate></item></channel></rss>
