<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using Mirrored Window Film on TV]]></title><description><![CDATA[<p dir="auto">So i was looking into purchasing some 2 way Acrylic Mirror for my project but like i’m making it out of a 42in tv its turning out to be quite expensive for the mirror. so i stumbled upon window film for $30 at my local homedepot but can’t find anywhere on the web if anyone has tried using this on top of a tv and how  it would be applied. if anyone  has any info on this please let me know. (<a href="http://www.homedepot.com/p/Gila-3-ft-x-15-ft-Mirror-Privacy-Window-Film-PRS361/100196546" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.homedepot.com/p/Gila-3-ft-x-15-ft-Mirror-Privacy-Window-Film-PRS361/100196546</a>) They have larger.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1361/using-mirrored-window-film-on-tv</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 12:18:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1361.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Jan 2017 06:42:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using Mirrored Window Film on TV on Thu, 19 Jan 2017 13:11:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atheose" aria-label="Profile: Atheose">@<bdi>Atheose</bdi></a> thanks for the information im going out in a few to go pick it up the film as i figure its only 30$ worth a try worse case ill buy a sheet of glass and place thar on top or just bit the bullet and by the Acrylic mirror… ill update when i have it on</p>
]]></description><link>https://forum.magicmirror.builders/post/11628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11628</guid><dc:creator><![CDATA[impuislupus]]></dc:creator><pubDate>Thu, 19 Jan 2017 13:11:07 GMT</pubDate></item><item><title><![CDATA[Reply to Using Mirrored Window Film on TV on Thu, 19 Jan 2017 13:07:55 GMT]]></title><description><![CDATA[<p dir="auto">I used that product for testing with success, though as others have mentioned it is not ideal. There is an accessory kit with squeegee/cutter/spray that you should get if you go this route and you will need to work very hard to make sure the end result is clean and bubble/blemish free. I think it’s fine for prototyping or if you’re not too picky but I would also suggest getting the mirrored glass.</p>
]]></description><link>https://forum.magicmirror.builders/post/11627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11627</guid><dc:creator><![CDATA[6jewels]]></dc:creator><pubDate>Thu, 19 Jan 2017 13:07:55 GMT</pubDate></item><item><title><![CDATA[Reply to Using Mirrored Window Film on TV on Thu, 19 Jan 2017 12:38:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> said in <a href="/topic/1361/using-mirrored-window-film-on-tv/2">Using Mirrored Window Film on TV</a>:</p>
<p dir="auto">The mirror film rarely lives up to the “mirror” part, sure it reflects light, but not enough to act as a usable mirror</p>
<p dir="auto">I’m going to disagree with this. I just applied some mirror film to a glass screen yesterday and it looks the exact same as a normal mirror, reflection-wise. No experience on whether this would work well when applied directly to a screen, though.</p>
<p dir="auto">HAVING SAID THAT, I totally agree with <a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a>’s second point: the film is extremely difficult to get perfect. I tried three times and each time there were tiny specks of imperfection in between the film and glass. Every speck of dust or tiny hair fibre shows up as a blemish on the mirror. It really sucks. I highly recommend buying mirrored glass instead.</p>
]]></description><link>https://forum.magicmirror.builders/post/11625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11625</guid><dc:creator><![CDATA[Atheose]]></dc:creator><pubDate>Thu, 19 Jan 2017 12:38:42 GMT</pubDate></item><item><title><![CDATA[Reply to Using Mirrored Window Film on TV on Sun, 08 Jan 2017 07:06:13 GMT]]></title><description><![CDATA[<p dir="auto">The mirror film rarely lives up to the “mirror” part, sure it reflects light, but not enough to act as a usable mirror, secondly it’s quite difficult for a person who have never applied foil or vinyl before to get a good result without bubbles and deformity.</p>
<p dir="auto">If you read around on this forum there are many builders who would strongly advice against any mirror foil, even the pro’s think the mirrorfoil is a real pain to get right.</p>
]]></description><link>https://forum.magicmirror.builders/post/10588</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10588</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 08 Jan 2017 07:06:13 GMT</pubDate></item></channel></rss>
