<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-sort wont load help needed]]></title><description><![CDATA[<p dir="auto">![alt text](image url)Hi every one…</p>
<p dir="auto">i have got an issue with MMM-SORT - the module wont load,</p>
<p dir="auto">is stuck on ( first the tide rushes in… )</p>
<p dir="auto">does anyone know why this is happened. i have valid key and also bough a credits so it should work correctly.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13613/mmm-sort-wont-load-help-needed</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:41:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13613.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Sep 2020 15:53:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 19:10:24 GMT]]></title><description><![CDATA[<p dir="auto">Sam, you are totally right by changing the port number it fixed the issue ;-)<br />
thanks you are genius!</p>
<p dir="auto">Kind regards<br />
Lukas</p>
]]></description><link>https://forum.magicmirror.builders/post/81409</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81409</guid><dc:creator><![CDATA[gauka12345]]></dc:creator><pubDate>Sun, 06 Sep 2020 19:10:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 19:01:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauka12345" aria-label="Profile: gauka12345">@<bdi>gauka12345</bdi></a> well something is using port 8080</p>
<p dir="auto">try moving mm to 8090</p>
<p dir="auto">edit the port in config.js</p>
]]></description><link>https://forum.magicmirror.builders/post/81408</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81408</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 19:01:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 18:54:18 GMT]]></title><description><![CDATA[<p dir="auto">thank you Sam ,</p>
<p dir="auto">hmm, i have got a XRPD running on this pi , so i could access it from my main PC</p>
<p dir="auto">also i have got another pi connected as the retro PI</p>
<p dir="auto">with the script nothing is happening</p>
<p dir="auto">pi@raspberrypi:~ $ sudo netstat -a | grep 8080<br />
pi@raspberrypi:~ $</p>
]]></description><link>https://forum.magicmirror.builders/post/81407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81407</guid><dc:creator><![CDATA[gauka12345]]></dc:creator><pubDate>Sun, 06 Sep 2020 18:54:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 18:39:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauka12345" aria-label="Profile: gauka12345">@<bdi>gauka12345</bdi></a> hm</p>
<p dir="auto">something else is using port 8080</p>
<p dir="auto">sudo netstat -a | grep 8080</p>
]]></description><link>https://forum.magicmirror.builders/post/81405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81405</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 18:39:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 18:29:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sam,</p>
<p dir="auto">pi@raspberrypi:~ $ pm2 status<br />
bash: pm2: command not found<br />
pi@raspberrypi:~ $ sudo pm2 status<br />
sudo: pm2: command not found<br />
pi@raspberrypi:~ $ pm2 stop 0<br />
]]></description><link>https://forum.magicmirror.builders/post/81402</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81402</guid><dc:creator><![CDATA[gauka12345]]></dc:creator><pubDate>Sun, 06 Sep 2020 18:29:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 18:05:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauka12345" aria-label="Profile: gauka12345">@<bdi>gauka12345</bdi></a> sounds like u are using pm2, and it started at boot.  do</p>
<p dir="auto">pm2 status<br />
pm2 stop 0</p>
]]></description><link>https://forum.magicmirror.builders/post/81396</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81396</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 18:05:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 17:51:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sam, please see below :</p>
<p dir="auto">i@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.12.0 start /home/pi/MagicMirror<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[2020-09-06 18:45:02.435] [LOG]    Starting MagicMirror: v2.12.0<br />
[2020-09-06 18:45:04.939] [LOG]    Loading config …<br />
[2020-09-06 18:45:05.050] [LOG]    Loading module helpers …<br />
[2020-09-06 18:45:05.115] [LOG]    No helper found for module: alert.<br />
[2020-09-06 18:45:05.127] [LOG]    No helper found for module: clock.<br />
[2020-09-06 18:45:29.773] [LOG]    Initializing new module helper …<br />
[2020-09-06 18:45:29.931] [LOG]    Module helper loaded: MMM-DarkSkyForecast<br />
[2020-09-06 18:46:00.633] [LOG]    Initializing new module helper …<br />
[2020-09-06 18:46:00.802] [LOG]    Module helper loaded: MMM-SORT<br />
[2020-09-06 18:46:01.052] [LOG]    No helper found for module: MMM-xiaomi.<br />
[2020-09-06 18:46:01.058] [LOG]    No helper found for module: MMM-Remote-Control.<br />
[2020-09-06 18:46:01.062] [LOG]    No helper found for module: MMM-NetworkConnection.<br />
[2020-09-06 18:46:01.281] [LOG]    No helper found for module: MMM-WorldTides.<br />
[2020-09-06 18:46:01.296] [LOG]    No helper found for module: MMM-Lunartic.<br />
[2020-09-06 18:46:01.301] [LOG]    No helper found for module: calendar_monthly.<br />
[2020-09-06 18:46:06.074] [LOG]    Initializing new module helper …<br />
[2020-09-06 18:46:06.076] [LOG]    Module helper loaded: calendar<br />
[2020-09-06 18:46:06.157] [LOG]    No helper found for module: MMM-AirQuality.<br />
[2020-09-06 18:46:07.196] [LOG]    Initializing new module helper …<br />
[2020-09-06 18:46:07.201] [LOG]    Module helper loaded: newsfeed<br />
[2020-09-06 18:46:07.204] [LOG]    All module helpers loaded.<br />
[2020-09-06 18:46:14.610] [LOG]    Starting server on port 8080 …<br />
[2020-09-06 18:46:15.474] [LOG]    Server started …<br />
[2020-09-06 18:46:15.477] [LOG]    Connecting socket for: MMM-DarkSkyForecast<br />
[2020-09-06 18:46:15.480] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]<br />
[2020-09-06 18:46:15.481] [LOG]    Connecting socket for: MMM-SORT<br />
[2020-09-06 18:46:15.483] [LOG]    Starting node_helper for: MMM-SORT<br />
[2020-09-06 18:46:15.484] [LOG]    Connecting socket for: calendar<br />
[2020-09-06 18:46:15.488] [LOG]    Starting node helper for: calendar<br />
[2020-09-06 18:46:15.495] [LOG]    Connecting socket for: newsfeed<br />
[2020-09-06 18:46:15.498] [LOG]    Starting node helper for: newsfeed<br />
[2020-09-06 18:46:15.504] [LOG]    Sockets connected &amp; modules started …<br />
[2020-09-06 18:46:28.584] [ERROR]  Whoops! There was an uncaught exception…<br />
[2020-09-06 18:46:28.598] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080<br />
at Server.setupListenHandle [as _listen2] (net.js:1226:14)<br />
at listenInCluster (net.js:1274:12)<br />
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)<br />
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {<br />
code: ‘EADDRINUSE’,<br />
errno: ‘EADDRINUSE’,<br />
syscall: ‘listen’,<br />
address: ‘127.0.0.1’,<br />
port: 8080<br />
}<br />
[2020-09-06 18:46:28.810] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[2020-09-06 18:46:28.819] [ERROR]  If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
[2020-09-06 18:46:28.911] [LOG]    Launching application.</p>
]]></description><link>https://forum.magicmirror.builders/post/81394</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81394</guid><dc:creator><![CDATA[gauka12345]]></dc:creator><pubDate>Sun, 06 Sep 2020 17:51:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-sort wont load help needed on Sun, 06 Sep 2020 16:48:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauka12345" aria-label="Profile: gauka12345">@<bdi>gauka12345</bdi></a> what might be shown on the console where u started mm, npm start, or the pm2 console, shown w pm2 logs --lines=???</p>
<p dir="auto">??? is a number, defaults to 15</p>
<p dir="auto">also may find info in the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors</p>
<p dir="auto">u can also filter by module, by placing a part of the module name in the filter field, sort, for example</p>
]]></description><link>https://forum.magicmirror.builders/post/81392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81392</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 16:48:12 GMT</pubDate></item></channel></rss>
