MagicMirror² v2.12.0 is available! For more information about this release, check out this topic.
Monitor Samsung P2470H at home
  • I have disassembled the monitor and have seen that I can’t give the signals per gpio.
    It’s a serial connection and I can’t simulate the protocol.
    So, is it possible to use the LCD Screen?
    It’s a m240hw01 v2
  • Project Sponsor
    @fox It’s possible. If you configure your Pi to turn off the signal to the HDMI port, the monitor should shut off automatically. It should remain off until it detects a signal again, whereupon it will turn itself back on.
    The MotionDetection module can do this for you with a Raspberry Pi camera. Otherwise, there is a module for using a PIR sensor.
