<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleDriveSlideShow npm-install shows no progress]]></title><description><![CDATA[<p dir="auto">Hello , I would like to user this module,  <a href="https://github.com/clegallic/MMM-GoogleDriveSlideShow" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/clegallic/MMM-GoogleDriveSlideShow</a></p>
<p dir="auto">It was fine for git clone operation, after that I tried to jump second step for “npm install” but it’s waiting 20 minutes, no progress.</p>
<p dir="auto">The screen was just like that :</p>
<pre><code>PS C:\Users\Emrah Aslan\D...\modules\MMM-GoogleDriveSlideShow&gt; npm install
[ .................] \ fetchMetadata: sill pacote range manifest for debug@4 fetched in 106ms
<p dir="auto">BTW I created credential.json file and put under secret folder.</p>
<p dir="auto">I believe without that , I couldn’t run</p>
<p dir="auto">cd ~/MagicMirror/modules/MMM-GooglePhotos<br />
node generate_token.js</p>
<pre><code>PS C:\modules\MMM-GoogleDriveSlideShow&gt; node generate-auth-token.js
internal/modules/cjs/loader.js:968
  throw err;
Error: Cannot find module 'googleapis'
Require stack:
- C:\modules\MMM-GoogleDriveSlideShow\generate-auth-token.js
?[90m    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)?[39m
?[90m    at Function.Module._load (internal/modules/cjs/loader.js:841:27)?[39m
?[90m    at Module.require (internal/modules/cjs/loader.js:1025:19)?[39m
?[90m    at require (internal/modules/cjs/helpers.js:72:18)?[39m
    at Object.&lt;anonymous&gt; (C:\Users\Emrah Aslan\Desktop\arneca\SmartWall\smartwall\modules\MMM-GoogleDriveSlideShow\generate-auth-token.js:3:18)
?[90m    at Module._compile (internal/modules/cjs/loader.js:1137:30)?[39m
?[90m    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)?[39m
?[90m    at Module.load (internal/modules/cjs/loader.js:985:32)?[39m
?[90m    at Function.Module._load (internal/modules/cjs/loader.js:878:14)?[39m
?[90m    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)?[39m {
  code: ?[32m'MODULE_NOT_FOUND'?[39m,
  requireStack: [
    ?[32m'C:\\Users\\Emrah Aslan\\Desktop\\arneca\\SmartWall\\smartwall\\modules\\MMM-GoogleDriveSlideShow\\generate-auth-token.js'?[39m
<p dir="auto">Guys, Please help me on this.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13650/mmm-googledriveslideshow-npm-install-shows-no-progress</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 16:25:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13650.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Sep 2020 13:51:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleDriveSlideShow npm-install shows no progress on Sat, 12 Sep 2020 17:22:46 GMT]]></title><description><![CDATA[<p dir="auto">I am not sure why it is not work, but it works with yarn install</p>
<p dir="auto">thanks for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/81653</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81653</guid><dc:creator><![CDATA[emrah_asl]]></dc:creator><pubDate>Sat, 12 Sep 2020 17:22:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleDriveSlideShow npm-install shows no progress on Sat, 12 Sep 2020 15:58:01 GMT]]></title><description><![CDATA[<p dir="auto">I’m working with yarn instead of npm I will let you know result</p>
]]></description><link>https://forum.magicmirror.builders/post/81648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81648</guid><dc:creator><![CDATA[emrah_asl]]></dc:creator><pubDate>Sat, 12 Sep 2020 15:58:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleDriveSlideShow npm-install shows no progress on Sat, 12 Sep 2020 15:45:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/emrah_asl" aria-label="Profile: emrah_asl">@<bdi>emrah_asl</bdi></a> note I had a typo, package-lock.json</p>
<p dir="auto">no idea why the delay</p>
]]></description><link>https://forum.magicmirror.builders/post/81647</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81647</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Sep 2020 15:45:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleDriveSlideShow npm-install shows no progress on Sat, 12 Sep 2020 15:15:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  I erased packahe-lock.jon file. Afterwards I typed npm-install still locked.</p>
<pre><code>PS C:\....\modules\MMM-GooglePhotos&gt; npm install
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
[ .................] \ fetchMetadata: sill pacote range manifest for p-limit@^2.0.0 fetched in 217ms
<p dir="auto">Waiting here.</p>
]]></description><link>https://forum.magicmirror.builders/post/81643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81643</guid><dc:creator><![CDATA[emrah_asl]]></dc:creator><pubDate>Sat, 12 Sep 2020 15:15:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleDriveSlideShow npm-install shows no progress on Sat, 12 Sep 2020 15:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sorry, missed problem above<br />
in the module folder erase package-lock.json if it exists and remove the node_modules folder, and then try npm install again</p>
]]></description><link>https://forum.magicmirror.builders/post/81638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81638</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Sep 2020 15:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleDriveSlideShow npm-install shows no progress on Sat, 12 Sep 2020 14:30:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/emrah_asl" aria-label="Profile: emrah_asl">@<bdi>emrah_asl</bdi></a> did u do the npm install in the module folder like the install instructions say?</p>
]]></description><link>https://forum.magicmirror.builders/post/81637</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81637</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Sep 2020 14:30:43 GMT</pubDate></item></channel></rss>
