<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mm-googlephotos]]></title><description><![CDATA[<ul>
<li>My google photos are trying to load with screen saying loading<br />
I’ve tried different positions but it’s still no t load<br />
What should I check first<br />
I’ve set it up fullscreen_below<br />
Size 600<br />
X 1<br />
Place my photos name in “New Mirror”</li>
</ul>
<p dir="auto">Any help please as  it’s change since I built my latest mirror.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13675/mm-googlephotos</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 12:36:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13675.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Sep 2020 20:37:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mm-googlephotos on Sat, 19 Sep 2020 12:32:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/videogame95" aria-label="Profile: videogame95">@<bdi>videogame95</bdi></a> auto install script?</p>
<p dir="auto">u mean this the install script from here?<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">if so, please send the install.log fil to my email userid. same userid on gmail.</p>
<p dir="auto">I am the author and maintainer of the script.</p>
]]></description><link>https://forum.magicmirror.builders/post/82046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82046</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Sep 2020 12:32:31 GMT</pubDate></item><item><title><![CDATA[Reply to Mm-googlephotos on Sat, 19 Sep 2020 12:25:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Hi auto install script Magic Mirror did not work for me .<br />
So I used the Manual install method and it all works.<br />
The only Problem I had is there was no custom .CSS folder<br />
So I had to use the main one . I of course made a copy of it.</p>
]]></description><link>https://forum.magicmirror.builders/post/82043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82043</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Sat, 19 Sep 2020 12:25:14 GMT</pubDate></item><item><title><![CDATA[Reply to Mm-googlephotos on Sat, 19 Sep 2020 03:53:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/videogame95" aria-label="Profile: videogame95">@<bdi>videogame95</bdi></a> auto install of what?</p>
]]></description><link>https://forum.magicmirror.builders/post/82022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82022</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Sep 2020 03:53:40 GMT</pubDate></item><item><title><![CDATA[Reply to Mm-googlephotos on Sat, 19 Sep 2020 02:58:00 GMT]]></title><description><![CDATA[<p dir="auto">Ok l give it a go thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/82020</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82020</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Sat, 19 Sep 2020 02:58:00 GMT</pubDate></item><item><title><![CDATA[Reply to Mm-googlephotos on Sat, 19 Sep 2020 02:20:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi Thanks for your advice , l have fix my calendar &amp;photos loading l had used auto install that did not work , once l use manual install it all works My advice to anyone building it for the first time do not use auto install nothing would load.</p>
<p dir="auto">Thanks again all fixed</p>
]]></description><link>https://forum.magicmirror.builders/post/82019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82019</guid><dc:creator><![CDATA[videogame95]]></dc:creator><pubDate>Sat, 19 Sep 2020 02:20:27 GMT</pubDate></item><item><title><![CDATA[Reply to Mm-googlephotos on Tue, 15 Sep 2020 21:40:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/videogame95" aria-label="Profile: videogame95">@<bdi>videogame95</bdi></a> check the messages where you start mm</p>
<p dir="auto">pm2 logs --lines=???<br />
??? is some number, default 15<br />
or the shell u use for npm start</p>
<p dir="auto">or look on the developers window, ctrl-shift-i on the pi keyboard, select the console tab and scroll up to see any errors. usually red text</p>
]]></description><link>https://forum.magicmirror.builders/post/81833</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81833</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Sep 2020 21:40:58 GMT</pubDate></item></channel></rss>
