<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2 modules with old data]]></title><description><![CDATA[<p dir="auto">Hello,<br />
in awe of my MM I noticed 2 display errors:</p>
<ul>
<li>agenda, there is a delay of 2 hours  in advance on the rendez-vous entered in Google Calendar, I added 2 “test” rendez-vous for tomorow and there the time is good, this delay occurs for the rendez-vous set from in 2 days.</li>
<li>MMM-soccer:<br />
the match day is wrong: it’s 3 and not 1, on the other hand the classification is good. I did a git pull and npm install but it doesn’t change anything</li>
</ul>
<p dir="auto">thanks for your help</p>
<p dir="auto"><img src="/assets/uploads/files/1600283242711-2020-09-16-210707_1080x1920_scrot.png" alt="2020-09-16-210707_1080x1920_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/13685/2-modules-with-old-data</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 23:01:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13685.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Sep 2020 19:04:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2 modules with old data on Thu, 17 Sep 2020 11:34:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> mm calendar bug, see sticky post at the top of the troubleshooting section for workaround til next release</p>
]]></description><link>https://forum.magicmirror.builders/post/81923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81923</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 17 Sep 2020 11:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to 2 modules with old data on Thu, 17 Sep 2020 10:41:12 GMT]]></title><description><![CDATA[<p dir="auto">For the agenda the problem comes from the recurrences, if I put a single appointment the time is good if the appointment is  a recurrence (every week for example) there is a delay of 2 hours in advance.<br />
I noted the appointments via the smartphone and the display via my pc is good.<br />
I do not understand…</p>
<p dir="auto"><img src="/assets/uploads/files/1600339086354-2020-09-17-123303_1080x1920_scrot.png" alt="2020-09-17-123303_1080x1920_scrot.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1600339097779-2020-09-17-123314_1080x1920_scrot.png" alt="2020-09-17-123314_1080x1920_scrot.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/81919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81919</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Thu, 17 Sep 2020 10:41:12 GMT</pubDate></item></channel></rss>
