<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cant Start MMPM GUI]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">first of all: I have absolutely 0 (and i mean it that way) programming experience. I have written maybe a few lines of html when I did some Age of Empires Scripts but thats it.</p>
<p dir="auto">So far I managed to setup Raspbian 10 (Buster) on my RP4, downloaded MagicMirror2 according to the instructions. Then I upgraded to Python 3.7.3 with PM2 (according to instructions and works)<br />
and then I installed MMPM (according to instructions)</p>
<p dir="auto">Current status:<br />
Magic Mirror is running. I have it on autostart when the RP4 boots. PM2 lets me use commands to start/stop etc.<br />
MMPM is running and I can access the CLI and use it as well as download/install modules.</p>
<p dir="auto">However whenever I give the CLI the mmpm open --gui command it opens the browser with a Bad Gateway result.</p>
<p dir="auto">I have been fooling around with the environment variables and at the moment they are set in this way:</p>
<p dir="auto">The MagicMirror config shows 192.168.1.11:8080 as the Mirrors Urls.<br />
In the env i have the same Url 192.168.1.11:8080<br />
and for the PM2 Process i have PM2 (however in the examples of the env settings the people who have pm2 write MagicMirro which really confuses me since i have a PM2 process but not a MagicMirror process)</p>
<p dir="auto">Can anyone help we with figuring out why the MMPM GUI doesnt work?<br />
I am happy to supply any information needed :)</p>
<p dir="auto">Thanks in advance and may you all have a great day!</p>
]]></description><link>https://forum.magicmirror.builders/topic/13704/cant-start-mmpm-gui</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 18:52:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13704.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Sep 2020 09:55:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cant Start MMPM GUI on Thu, 10 Dec 2020 15:23:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Still don’t like the response he made to you about not advising people to use your scripts.</p>
]]></description><link>https://forum.magicmirror.builders/post/85620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85620</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Thu, 10 Dec 2020 15:23:30 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Thu, 10 Dec 2020 15:05:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> none of my scripts address MMPM<br />
(MagicMirror Package Manager)</p>
]]></description><link>https://forum.magicmirror.builders/post/85619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85619</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 10 Dec 2020 15:05:33 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Thu, 10 Dec 2020 14:57:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zar" aria-label="Profile: Zar">@<bdi>Zar</bdi></a> You could just issue a <code>pm2 delete mm</code> and then  <code>pm2 save</code> which will get rid of pm2 restarting the mirror.  The feature helps with crashes and restarts the mirror automatically.<br />
The scripts from <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  is awesome and has helped 100’s on the forum.</p>
]]></description><link>https://forum.magicmirror.builders/post/85618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85618</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Thu, 10 Dec 2020 14:57:47 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Thu, 10 Dec 2020 14:05:36 GMT]]></title><description><![CDATA[<p dir="auto">I have exactly the same problem: I can’t get MMPM get to autostart after reboot. Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/post/85615</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85615</guid><dc:creator><![CDATA[mr190e]]></dc:creator><pubDate>Thu, 10 Dec 2020 14:05:36 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Sun, 04 Oct 2020 15:34:46 GMT]]></title><description><![CDATA[<p dir="auto">New question about the GUI here:<br />
I have 2 MM installations on 2 R3B+.<br />
Both the same config. Both the same Raspian Buster.</p>
<p dir="auto">On one, GUI is working as intended.<br />
On the other, for a while now (worked before), I have to reinstall the MMPM GUI after every reboot with mmpm install --gui, then it works.<br />
After a reboot -&gt; 502 Bad gateway.<br />
MMPM 2.05.</p>
<p dir="auto">Anyone already came across this and has a solution available?</p>
]]></description><link>https://forum.magicmirror.builders/post/82835</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82835</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Sun, 04 Oct 2020 15:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Tue, 22 Sep 2020 15:56:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zar" aria-label="Profile: Zar">@<bdi>Zar</bdi></a> pm2’s job is to restart , you can always minimize MM (alt-spacebar, n) and then use pm2 to stop,<br />
(alt-ctrl-t to open a terminal window)<br />
or use an ssh ssession to the pi and pm2 stop…</p>
<p dir="auto">or not accept pm2 during install … all kinds of ways to handle it…</p>
<p dir="auto">alt-spacebar, n to minimize is the same as for Windows on any app.</p>
]]></description><link>https://forum.magicmirror.builders/post/82222</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82222</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 22 Sep 2020 15:56:27 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Tue, 22 Sep 2020 15:44:51 GMT]]></title><description><![CDATA[<p dir="auto">Please do me and future askers a favor and dont tell them to use your script. Thats the second flash of the raspberrie now…</p>
<p dir="auto">Your script basically makes it impossible to stop MM because it just restarts npm and PM2 as well as MM every single time you try to shut it down.</p>
]]></description><link>https://forum.magicmirror.builders/post/82221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82221</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 22 Sep 2020 15:44:51 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 17:21:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zar" aria-label="Profile: Zar">@<bdi>Zar</bdi></a> i would just use my scripts…</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/82169</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82169</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Sep 2020 17:21:26 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 17:06:36 GMT]]></title><description><![CDATA[<p dir="auto">Well mmpm was not the only thing not working ;)</p>
<p dir="auto">I will try to install Magic Mirror through the MMPM commands this time. Maybe that helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/82168</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82168</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 21 Sep 2020 17:06:36 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 17:00:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> seems the hard way, vs asking the MMPM author</p>
]]></description><link>https://forum.magicmirror.builders/post/82166</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82166</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Sep 2020 17:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 16:51:39 GMT]]></title><description><![CDATA[<p dir="auto">I did look at the wiki but none of the mmpm commands help with loosing the connection. The right env in this case is pm2 as i figured out by trying under which circumstances mmpm can control mm.</p>
<p dir="auto">However since until now not a single module could be loaded i will flash the SD card and start from scratch.</p>
]]></description><link>https://forum.magicmirror.builders/post/82164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82164</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 21 Sep 2020 16:51:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 14:17:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zar" aria-label="Profile: Zar">@<bdi>Zar</bdi></a> I would look at the mmpm wiki<br />
<a href="https://github.com/Bee-Mar/mmpm/wiki/Command-Line-Options" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/wiki/Command-Line-Options</a></p>
<p dir="auto">and open in issue if u need more help</p>
]]></description><link>https://forum.magicmirror.builders/post/82144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82144</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Sep 2020 14:17:30 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 14:08:37 GMT]]></title><description><![CDATA[<p dir="auto">You were absolutely right about the http</p>
<p dir="auto">I changed the process now in the env file to MagicMirror. However now there is no connection between mmpm and mm anymore.</p>
<p dir="auto">Conclusion: now i have the gui but i mmpm cannot access active modules anymore. i tried switching the process in the env back to pm2 but that doesnt help either.</p>
]]></description><link>https://forum.magicmirror.builders/post/82142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82142</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 21 Sep 2020 14:08:37 GMT</pubDate></item><item><title><![CDATA[Reply to Cant Start MMPM GUI on Mon, 21 Sep 2020 11:56:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zar" aria-label="Profile: Zar">@<bdi>Zar</bdi></a> that url should be <a href="http://192.168.1.11:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.1.11:8080</a></p>
<p dir="auto">right?</p>
<p dir="auto">the desktop browser will add http://<br />
if it is missing, programs are not so nice</p>
<p dir="auto">the thing you started MagicMirror with is the MagicMirror process.</p>
]]></description><link>https://forum.magicmirror.builders/post/82129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Sep 2020 11:56:34 GMT</pubDate></item></channel></rss>
