<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pm2 starts up then stops then starts up, then stops etc ...]]></title><description><![CDATA[<p dir="auto">after having made the requested update (despite having installed MMM-UpdateNotification) on the MMM-GoogleAssistant 1.2.2 module in 1.2.4, pm2 starts up then stops then starts up, then stops etc …<br />
If I comment on the MMM-GoogleAssistant in the config.js pm2 starts without stopping.<br />
Is it due to the conflict between Bugsounet and MichMich?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13708/pm2-starts-up-then-stops-then-starts-up-then-stops-etc</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 02:05:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13708.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Sep 2020 12:31:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pm2 starts up then stops then starts up, then stops etc ... on Tue, 22 Sep 2020 13:01:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> well, its not PM2, its that MM fails to start for some reason, and so, get restarted (thats pm2’s job, keep task running)</p>
<p dir="auto">I would guess its because Bugsounet has removed his modules, and/or made them not run under MichMich MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/82209</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82209</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 22 Sep 2020 13:01:48 GMT</pubDate></item></channel></rss>
