<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[delete sudo commande ?]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/13712/delete-sudo-commande</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 17:53:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13712.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Sep 2020 08:52:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to delete sudo commande ? on Wed, 23 Sep 2020 14:14:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , ok thanks you.</p>
]]></description><link>https://forum.magicmirror.builders/post/82277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82277</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Wed, 23 Sep 2020 14:14:13 GMT</pubDate></item><item><title><![CDATA[Reply to delete sudo commande ? on Wed, 23 Sep 2020 13:51:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> as I said &gt;I think u could leave the others.</p>
]]></description><link>https://forum.magicmirror.builders/post/82276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82276</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 13:51:44 GMT</pubDate></item><item><title><![CDATA[Reply to delete sudo commande ? on Wed, 23 Sep 2020 13:40:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> : I’m really sorry because I don’t think I make myself understood.<br />
I deleted MMM-PIR and MMM-PIR-Sensor by doing <code> rm -rf modules/MMM-PIR</code> and <code> rm -rf modules/MMM-PIR-Sensor</code> so the MMM-PIR and MMM-PIR-Sensor modules are correctly removed and my MM works correctly.<br />
i am just wondering if i should and how to delete <code>sudo usermod -a -G gpio pi</code> and <code>sudo chmod u+s /opt/vc/bin/tvservice &amp;&amp; sudo chmod u+s /bin/chvt</code> …</p>
]]></description><link>https://forum.magicmirror.builders/post/82275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82275</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Wed, 23 Sep 2020 13:40:40 GMT</pubDate></item><item><title><![CDATA[Reply to delete sudo commande ? on Wed, 23 Sep 2020 13:31:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> well u didn’t want to delete modules, cause that wiped out everything</p>
<p dir="auto">I think u could leave the others.</p>
]]></description><link>https://forum.magicmirror.builders/post/82274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82274</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 13:31:33 GMT</pubDate></item><item><title><![CDATA[Reply to delete sudo commande ? on Wed, 23 Sep 2020 13:12:32 GMT]]></title><description><![CDATA[<p dir="auto">@sdeweil I’m sorry but yes I had used <code>rm -rf modules/</code>but my question is about <code> sudo usermod -a -G gpio pi</code> and <code>sudo chmod u+s /opt/vc/bin/tvservice &amp;&amp; sudo chmod u+s /bin/chvt</code> should they be deleted and how ?</p>
]]></description><link>https://forum.magicmirror.builders/post/82273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82273</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Wed, 23 Sep 2020 13:12:32 GMT</pubDate></item><item><title><![CDATA[Reply to delete sudo commande ? on Wed, 23 Sep 2020 12:02:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> on linux the delete file command is rm</p>
<p dir="auto">the delete folder is rmdir</p>
<p dir="auto">you can also do both at once</p>
<p dir="auto">rm -rf foldername</p>
<p dir="auto">a reminder that Google is your friend</p>
<pre><code>how do I delete a file in Linux
<p dir="auto">would have given you assistance without waiting for us</p>
]]></description><link>https://forum.magicmirror.builders/post/82271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82271</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 12:02:23 GMT</pubDate></item></channel></rss>
