<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SORT  still needs API key ?]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/13714/mmm-sort-still-needs-api-key</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 20:12:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13714.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Sep 2020 15:32:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 21:08:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes, I tried it but the parameter (margin/width/high etc.) drives me crazy…it was much easier for me to create a local html. And it is not time-critical. updating every 24 hours will be enough.</p>
<p dir="auto">Thomas</p>
]]></description><link>https://forum.magicmirror.builders/post/82306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82306</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Wed, 23 Sep 2020 21:08:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 21:05:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thgmirror" aria-label="Profile: thgmirror">@<bdi>thgmirror</bdi></a>  u might be able to use one of the iframe modules for that</p>
]]></description><link>https://forum.magicmirror.builders/post/82305</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82305</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 21:05:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 21:04:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a>  as a workaround you can show the content of a website with the following HTML-code (as an example Cadiz in Spain):<br />
<img src="/assets/uploads/files/1600894700161-bb3c5a41-9f7e-40ce-93d5-c4df98ee8280-image.png" alt="bb3c5a41-9f7e-40ce-93d5-c4df98ee8280-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Store this as a file in the modules-folder with the extension html and use SmartWebDisplay to display it.<br />
To get another location go to <a href="https://www.tideking.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.tideking.com/</a> and use the search function to find it. Take the url and enter it in the HTML.</p>
<p dir="auto">Leads to<br />
<img src="/assets/uploads/files/1600895068266-47396c27-0f27-4039-9408-813be00e86f1-image.png" alt="47396c27-0f27-4039-9408-813be00e86f1-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/82304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82304</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Wed, 23 Sep 2020 21:04:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 15:46:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a>  no, i do not know</p>
]]></description><link>https://forum.magicmirror.builders/post/82289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82289</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 15:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 15:46:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
ok, thanks you.<br />
do you know if it exist a module without buy a key to have the tides ?</p>
]]></description><link>https://forum.magicmirror.builders/post/82288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82288</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Wed, 23 Sep 2020 15:46:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 15:37:56 GMT]]></title><description><![CDATA[<p dir="auto">ok, thanks you.</p>
]]></description><link>https://forum.magicmirror.builders/post/82286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82286</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Wed, 23 Sep 2020 15:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SORT  still needs API key ? on Wed, 23 Sep 2020 15:36:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> it will work if you BUY a key. otherwise not</p>
<p dir="auto">no dependencies means the code is self contained, no other libraries used.  (not useful info if no apikey)</p>
]]></description><link>https://forum.magicmirror.builders/post/82285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82285</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Sep 2020 15:36:35 GMT</pubDate></item></channel></rss>
