<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Remote-Control Error After Accessing From Browser After Installation]]></title><description><![CDATA[<p dir="auto">I just installed and configured the MMM-Remote-Control Module.  I tried accessing it from my phone and from a different computer after I added the IP addresses to the whitelist.  On both systems, I get the following error:</p>
<p dir="auto">{“status”:“error”,“reason”:“unknown_command”,“info”:“original input: {}”}</p>
<p dir="auto">That is the only line that shows up in the browser.  Any advice?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13751/mmm-remote-control-error-after-accessing-from-browser-after-installation</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 21:37:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13751.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Oct 2020 02:39:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Remote-Control Error After Accessing From Browser After Installation on Wed, 20 Apr 2022 13:39:24 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply  Sam.<br />
I had done that which you instruct.<br />
My problem, I just found, I had forgotten to add “.html” at the end as in “http//:192.168.xx.x:8080/remote.html” which threw this error message:- {“status”:“error”,“reason”:“unknown_command”,“info”:“original input: {}”}<br />
Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/101293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101293</guid><dc:creator><![CDATA[rudiau]]></dc:creator><pubDate>Wed, 20 Apr 2022 13:39:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control Error After Accessing From Browser After Installation on Wed, 20 Apr 2022 12:09:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rudiau" aria-label="Profile: rudiau">@<bdi>rudiau</bdi></a> on your pi, by default,  mm is set to NOT allow other system to access</p>
<p dir="auto">you need to change the mm config.js settings</p>
<p dir="auto">address:“0.0.0.0”<br />
and<br />
ipWhitelist:[]</p>
<p dir="auto">to allow any system (computer,  phone, tablet) on your local network</p>
]]></description><link>https://forum.magicmirror.builders/post/101291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101291</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Apr 2022 12:09:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control Error After Accessing From Browser After Installation on Wed, 20 Apr 2022 12:04:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi schwarem,<br />
Old post I know.<br />
Did you ever find a solution as I have the same problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/101290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101290</guid><dc:creator><![CDATA[rudiau]]></dc:creator><pubDate>Wed, 20 Apr 2022 12:04:50 GMT</pubDate></item></channel></rss>
