<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar failed to load Gmail ical]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/12195/calendar-failed-to-load">Calendar failed to load.</a><br />
in the solution provided by <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> worked wonderfully on old versions of MagicMirror, but in a brand new instalation I got the same error but does not work at all adding the <strong>case ‘’:</strong> to the file <strong>/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js</strong></p>
<p dir="auto">Any suggestions? 🙂</p>
<pre><code>[2020-10-02 01:54:04.535] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
[2020-10-02 01:54:08.276] [ERROR]  Whoops! There was an uncaught exception...
[2020-10-02 01:54:08.277] [ERROR]  Error: Unknown RRULE property 'RRULE'
    at /home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1191:23
    at Array.forEach (&lt;anonymous&gt;)
    at parseRrule (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1149:11)
    at parseLine (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1138:20)
    at Array.map (&lt;anonymous&gt;)
    at Function.parseString (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1110:41)
    at Function.RRule.fromString (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:2135:32)
    at Object.END (/home/pi/MagicMirror/node_modules/node-ical/ical.js:446:30)
    at Object.handleObject (/home/pi/MagicMirror/node_modules/node-ical/ical.js:483:39)
    at Object.parseLines (/home/pi/MagicMirror/node_modules/node-ical/ical.js:534:18)
[2020-10-02 01:54:08.280] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2020-10-02 01:54:08.281] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
]]></description><link>https://forum.magicmirror.builders/topic/13752/calendar-failed-to-load-gmail-ical</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 22:39:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13752.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Oct 2020 07:10:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar failed to load Gmail ical on Mon, 05 Oct 2020 15:26:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barucomx" aria-label="Profile: barucomx">@<bdi>barucomx</bdi></a> i need a short ics file from you that causes  this problem so we can fix it…</p>
]]></description><link>https://forum.magicmirror.builders/post/82901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82901</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 05 Oct 2020 15:26:50 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar failed to load Gmail ical on Fri, 02 Oct 2020 12:13:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barucomx" aria-label="Profile: barucomx">@<bdi>barucomx</bdi></a> can u send me a little ics with that one event? we have an open issue, but can’t recreate it…</p>
]]></description><link>https://forum.magicmirror.builders/post/82656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82656</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Oct 2020 12:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar failed to load Gmail ical on Fri, 02 Oct 2020 07:27:49 GMT]]></title><description><![CDATA[<p dir="auto">found a ‘solution’ in the file <strong>/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js</strong> just commented the default action and now I can see the calendar :astonished_face:</p>
<pre><code>                        case 'BYEASTER':
                            options.byeaster = Number(value);
                            break;
                        case '':
                            break;
                        default:
            //                throw new Error("Unknown RRULE property '" + key + "'");
            ```</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/82649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82649</guid><dc:creator><![CDATA[barucomx]]></dc:creator><pubDate>Fri, 02 Oct 2020 07:27:49 GMT</pubDate></item></channel></rss>
