MagicMirror² v2.13.0 is available! For more information about this release, check out this topic.
2.13 back screen translation file error fix
  • looks like we have surfaced an old problem. some modules provide translations in json files, but have comments /* */, or //
    which are not allowed.
    edit the files and remove the comment(s)
    you would see this error in the developers window
    0.0.0.0/:4 Uncaught SyntaxError: Unexpected token / in JSON at position 44
        at JSON.parse ()
        at XMLHttpRequest.xhr.onreadystatechange
    to open the developers window, ctrl-shift-i on the mm keyboard, select the tab labeled ‘console’ and scroll up or down to see that errors
  • a fix has been provided and is now available via the developers branch
    to get there
    if you did manual install
    cd ~/MagicMirror
    git checkout develop
    git pull
    restart MagicMirror as normal
    if you used my install script
    cd ~/MagicMirror
    git fetch origin develop:develop
