<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[First start from the mirror does not work]]></title><description><![CDATA[<p dir="auto">Hello,<br />
to only sorry for my bad english .<br />
I have made the manual installation and it is the fault (picture)<br />
The mirror is black and no module is loaded .<br />
I hope you can help me!<img src="/uploads/files/1463996111411-snip_20160523113415.png" alt="0_1463996068490_snip_20160523113415.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/138/first-start-from-the-mirror-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 16:54:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/138.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 May 2016 09:36:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to First start from the mirror does not work on Tue, 05 Jul 2016 12:40:49 GMT]]></title><description><![CDATA[<p dir="auto">I had the same erorr and I did use the full Jessie distribution. In my case “npm start” showed  the same error but the problem was before at “npm install”.</p>
<p dir="auto">I never really took the time to watch the entire npm install routine, because it took a while. I had my rasbperry connected via usb on my tv. And while running npm install it rebooted! So in my case it was caused by an inadequate power supply. Switched to a plug and everything worked fine.</p>
<p dir="auto">Perhaps somebody runs into the same error like me.</p>
]]></description><link>https://forum.magicmirror.builders/post/2225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2225</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 05 Jul 2016 12:40:49 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Tue, 14 Jun 2016 20:49:39 GMT]]></title><description><![CDATA[<p dir="auto">Right, the lite version wouldn’t have any of those packages installed, nor would it have an X-server, so you would’ve had to do that yourself. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/1649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1649</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 14 Jun 2016 20:49:39 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Tue, 14 Jun 2016 20:26:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Hi! Glad you finally got around to testing this! I did in fact use the lite version of Jessie, so that would explain it then.</p>
]]></description><link>https://forum.magicmirror.builders/post/1647</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1647</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Tue, 14 Jun 2016 20:26:32 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Tue, 14 Jun 2016 17:06:18 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I <em>finally</em> had time last night to run through a complete setup and install, from taking the rpi out of its box to having MM up and running. I did <strong>not</strong> have to manually install any of the aforementioned packages. Which makes me wonder, <a class="plugin-mentions-user plugin-mentions-a" href="/user/eof" aria-label="Profile: EoF">@<bdi>EoF</bdi></a>, were you running the full Jessie distribution, or Jessie-Lite? If it’s Jessie-Lite, you would’ve had to install a lot more than just those few pieces as it does not come with an X-server.</p>
<p dir="auto">Anyway, I’ll have a step-by-step tutorial written up soon …hmm, let’s check calendar … oh yeah, some time in 2036. <em></em></p>
]]></description><link>https://forum.magicmirror.builders/post/1642</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1642</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 14 Jun 2016 17:06:18 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Tue, 07 Jun 2016 02:13:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Haha I know that feeling!</p>
]]></description><link>https://forum.magicmirror.builders/post/1416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1416</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Tue, 07 Jun 2016 02:13:58 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 23:06:59 GMT]]></title><description><![CDATA[<p dir="auto">Will do. Right after I inspect the 3D print that I left going since last night, and I start the next print. And after I swap a laptop with a friend. And after I have dinner. And after I help another friend with their phone. And after i do some laser cutting of mock up pieces for an art piece. And after I dig up the electronic bits I need for a kid’s costume. And after I … and after … and … oh you’ll hear from me some time in 2036. <em>Really, I promise.</em></p>
<p dir="auto"><em>(Is there ever such a thing as having too many projects going at the same time?)</em></p>
]]></description><link>https://forum.magicmirror.builders/post/1410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1410</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 23:06:59 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 22:21:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> haha alright go for it! Let us know what comes of it.</p>
]]></description><link>https://forum.magicmirror.builders/post/1409</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1409</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Mon, 06 Jun 2016 22:21:39 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 21:45:30 GMT]]></title><description><![CDATA[<p dir="auto">You know, I have a spare rpi-3 sitting at home. I’ll wipe it clean and start fresh when I get home later and see if I run into issues. All in the name of science!</p>
]]></description><link>https://forum.magicmirror.builders/post/1405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1405</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 21:45:30 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 21:44:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> I did the manual install for mine anyways, but I could have sworn I did an update / upgrade but I may be wrong.</p>
<p dir="auto">Maybe it’s something that can just be added to the install instructions as a small note.</p>
]]></description><link>https://forum.magicmirror.builders/post/1404</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1404</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Mon, 06 Jun 2016 21:44:11 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 21:37:22 GMT]]></title><description><![CDATA[<p dir="auto">I vote no because that’s outside the scope of MM. However, we could adjust the installer to pause and ask the user if they have performed an update/upgrade on their base rpi before continuing on with the MM install. This gives the user an opportunity to exit the installer and do the requires prerequisites before returning to the installer (at which point they can then say ‘yes’ to the question.)</p>
]]></description><link>https://forum.magicmirror.builders/post/1403</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1403</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 21:37:22 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 21:23:56 GMT]]></title><description><![CDATA[<p dir="auto">Mhh maybe we should add those dependencies and/or <code>apt-get upgrade</code> to the installer script?</p>
]]></description><link>https://forum.magicmirror.builders/post/1401</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1401</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Mon, 06 Jun 2016 21:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 19:52:30 GMT]]></title><description><![CDATA[<p dir="auto">Interesting as I didn’t have to do that as a separate step. However, as I posted <a href="https://forum.magicmirror.builders/topic/185/prereqs-on-your-raspberry-pi">in a different thread</a> yesterday, keeping the base software on your Raspberry Pi is important.</p>
]]></description><link>https://forum.magicmirror.builders/post/1393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1393</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 19:52:30 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Mon, 06 Jun 2016 21:22:23 GMT]]></title><description><![CDATA[<p dir="auto">As an update to my situation, I was able to get mine working by installing electron dependencies.</p>
<p dir="auto"><code>sudo apt-get install libgtk2.0-0 libnotify4 libgconf2-4 libnss3</code></p>
<p dir="auto">I am running a pi 3 with Jessie by the way.</p>
<p dir="auto">FYI <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/paviro" aria-label="Profile: paviro">@<bdi>paviro</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/1392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1392</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Mon, 06 Jun 2016 21:22:23 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Sat, 04 Jun 2016 20:03:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> Hi! I am running npm start directly on the pi, and I get the same exact error.</p>
]]></description><link>https://forum.magicmirror.builders/post/1271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1271</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Sat, 04 Jun 2016 20:03:44 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Sat, 04 Jun 2016 18:41:55 GMT]]></title><description><![CDATA[<p dir="auto">Maybe I’m missing something here, but it seems you try to run <code>npm start</code> from a remote shell. That does not work since it doesn’t know on which screen to start. Try: <code>DISPLAY=:0 npm start</code></p>
]]></description><link>https://forum.magicmirror.builders/post/1256</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1256</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sat, 04 Jun 2016 18:41:55 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Sat, 04 Jun 2016 17:48:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi I am having this same issue. Did you ever get it working?</p>
]]></description><link>https://forum.magicmirror.builders/post/1250</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1250</guid><dc:creator><![CDATA[EoF]]></dc:creator><pubDate>Sat, 04 Jun 2016 17:48:42 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Sat, 28 May 2016 08:20:54 GMT]]></title><description><![CDATA[<p dir="auto">yes i have install the npm in the MM Folder ,  only compliment, clock and news works other moduls come a error ( no config file )</p>
]]></description><link>https://forum.magicmirror.builders/post/1168</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1168</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Sat, 28 May 2016 08:20:54 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Fri, 27 May 2016 00:39:13 GMT]]></title><description><![CDATA[<p dir="auto">Beats me, did you run npm install in the MagicMirror folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/1119</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1119</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Fri, 27 May 2016 00:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Thu, 26 May 2016 19:29:30 GMT]]></title><description><![CDATA[<p dir="auto">Many thanks for your help and your tip! but only tow module works =( the clock an the compliments why this ?<br />
Whenever I will add another module of the screen black!<br />
i have install the electron.js again but<br />
the add the module as in the proceeds described readme does not work !</p>
]]></description><link>https://forum.magicmirror.builders/post/1115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1115</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Thu, 26 May 2016 19:29:30 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Thu, 26 May 2016 18:40:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samydp" aria-label="Profile: samydp">@<bdi>samydp</bdi></a> all you should have to do is change the language portion of your <code>config.js</code> from<br />
<code>language: 'en',</code> -&gt; <strong><code>language: 'de',</code></strong></p>
<p dir="auto">As for the rest of your modules, I recommend adding them one by one to your <code>config.js</code> file to make sure they work.  If you get that electron.js error, it was on the module you just added.</p>
<p dir="auto">-Luke</p>
]]></description><link>https://forum.magicmirror.builders/post/1114</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1114</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Thu, 26 May 2016 18:40:17 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Thu, 26 May 2016 18:19:48 GMT]]></title><description><![CDATA[<p dir="auto">your config works !!! juhu thx but i have a other wrong :/</p>
<p dir="auto">i will the language from the clock in germany</p>
<pre><code>Module.register("clock",{
	// Module config defaults.
	defaults: {
		timeFormat: config.timeFormat,
		displaySeconds: true,
		showPeriod: true,
		showPeriodUpper: false,
		clockBold: true
	// Define required scripts.
	getScripts: function() {
		return ["moment.js"];
	// Define start sequence.
	start: function() {
		Log.info("Starting module: " + this.name);
		// Schedule update interval.
		var self = this;
		setInterval(function() {
			self.updateDom();
		}, 1000);
		// Set locale.
		moment.locale(config.language);
<p dir="auto"><strong>Note from Moderator:</strong> Please use proper Markdown on code snippets for easier reading.</p>
]]></description><link>https://forum.magicmirror.builders/post/1108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1108</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Thu, 26 May 2016 18:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Thu, 26 May 2016 16:15:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samydp" aria-label="Profile: samydp">@<bdi>samydp</bdi></a>, rename your <code>config.js</code> to <code>config.js.old</code> and make this your new <code>config.js</code>.  Try running the program with this, if you see compliments on the bottom screen, you know that magicmirror works fine and the problem is in one of the other modules.  It’s a place to start.  If you’re still getting the electron errors, try rerunning npm install again in your MagicMirror directory.</p>
<hr />
<pre><code>var config = {
	port: 8080,
	language: 'en',
	timeFormat: 24,
	units: 'metric',
			module: 'alert',
			module: 'compliments',
			position: 'lower_third'
]]></description><link>https://forum.magicmirror.builders/post/1106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1106</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Thu, 26 May 2016 16:15:22 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Thu, 26 May 2016 13:28:17 GMT]]></title><description><![CDATA[<p dir="auto">Update:<br />
can you show me how the modules in the config investing so that the screen indicating?:o</p>
]]></description><link>https://forum.magicmirror.builders/post/1097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1097</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Thu, 26 May 2016 13:28:17 GMT</pubDate></item><item><title><![CDATA[Reply to First start from the mirror does not work on Thu, 26 May 2016 08:52:29 GMT]]></title><description><![CDATA[<p dir="auto">how exactly do you mean? !<br />
I would now delete all modules except the komentare . or how to do it ?<br />
and thank you !!!</p>
]]></description><link>https://forum.magicmirror.builders/post/1092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1092</guid><dc:creator><![CDATA[samydp]]></dc:creator><pubDate>Thu, 26 May 2016 08:52:29 GMT</pubDate></item></channel></rss>
