<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Happy Halloween! I kinda took over the office mirror for a month]]></title><description><![CDATA[<p dir="auto">We’re back in the office after a brief break for a plague. So I got into the mirrors and uploaded some moving portrait videos.</p>
<p dir="auto">First, the right side:<br />
<a href="https://youtu.be/5647bHkcUw0" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/5647bHkcUw0</a></p>
<p dir="auto">And on the left side:<br />
<a href="https://youtu.be/HT6_DEtfaSc" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/HT6_DEtfaSc</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/13811/happy-halloween-i-kinda-took-over-the-office-mirror-for-a-month</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 23:10:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13811.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Oct 2020 13:50:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Mon, 16 Nov 2020 03:33:11 GMT]]></title><description><![CDATA[<p dir="auto">Sorry about the delay! Lots of other projects going on at the Fortress Hepler.</p>
<p dir="auto">To answer your questions, <a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> :</p>
<ul>
<li>I created a simple one-line script that plays the video on a loop and then added it to the PM2 management via <code>pm2 start boo.sh</code> and <code>pm2 save</code>. I disabled the Magic Mirror interface via <code>pm2 stop MagicMirror</code> and <code>pm2 save</code>. Now when then mirror boots, PM2 only watches over the script that calls the video playback.</li>
<li>It’s not running the MagicMirror interface. No sense using all that overhead and calls to the weather API when it’s not being displayed.</li>
<li>Caveat: the right display runs a video on loop under normal circumstances. Commenting out the one line that runs that video file and adding a line to play a different video file was trivial.</li>
<li>Yes, VLC  has the option to play a playlist or single file on a loop. You can find the command line options at <a href="https://wiki.videolan.org/VLC_command-line_help/" target="_blank" rel="noopener noreferrer nofollow ugc">VLC Help</a></li>
<li>Not really. The file is already on the disk and sized to the resolution of the monitor. There’s no CPU or GPU intensive tasks and the on board hardware acceleration takes care of most of it.</li>
</ul>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elitecybernet" aria-label="Profile: elitecybernet">@<bdi>elitecybernet</bdi></a> - Yeah, there is sound included in the video files. I turned it down as it got really distracting really quickly. The video is only like 3 minutes long and hearing the demonic laughter every 3 minutes got old. I think the left portrait was at 50% volume and the right was completely muted.</p>
<p dir="auto">Now that Halloween is gone, I reverted the left &amp; right displays to their original format. Because PM2 manages the scripts, it took all of 30 seconds per display. The hardest part was remembering their IP address so I could log in.</p>
]]></description><link>https://forum.magicmirror.builders/post/84718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84718</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 16 Nov 2020 03:33:11 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Tue, 10 Nov 2020 10:21:11 GMT]]></title><description><![CDATA[<p dir="auto">any sound for that sir ?  <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/84469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84469</guid><dc:creator><![CDATA[elitecybernet]]></dc:creator><pubDate>Tue, 10 Nov 2020 10:21:11 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Mon, 26 Oct 2020 20:46:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a><br />
Really loving that … A lot!</p>
<p dir="auto">Couple questions…</p>
<p dir="auto">How did you disable the interface to be able to show this on it’s own? Is it still playing on MM, but with everything else stopped?</p>
<p dir="auto">Video File?.. where did you store it and what player did you use? What is the name of the first one?</p>
<p dir="auto">Did the player give the loop option?</p>
<p dir="auto">Is this very CPU intensive, seeing that you disabled the MM interface?<br />
Thanks 😉</p>
]]></description><link>https://forum.magicmirror.builders/post/83988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83988</guid><dc:creator><![CDATA[johnnyboy]]></dc:creator><pubDate>Mon, 26 Oct 2020 20:46:56 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Sun, 25 Oct 2020 19:38:24 GMT]]></title><description><![CDATA[<p dir="auto">great stuff. looks very good :thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/83951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83951</guid><dc:creator><![CDATA[MC]]></dc:creator><pubDate>Sun, 25 Oct 2020 19:38:24 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Sun, 25 Oct 2020 13:18:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> very nice work :D</p>
]]></description><link>https://forum.magicmirror.builders/post/83937</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83937</guid><dc:creator><![CDATA[RaspiManu]]></dc:creator><pubDate>Sun, 25 Oct 2020 13:18:26 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Sat, 24 Oct 2020 14:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberphox" aria-label="Profile: cyberphox">@<bdi>cyberphox</bdi></a> even better!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/83896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83896</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 24 Oct 2020 14:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Tue, 20 Oct 2020 11:22:55 GMT]]></title><description><![CDATA[<p dir="auto">I have a boatload of those AtmosphereX videos…great for Halloween and Christmas stuff</p>
]]></description><link>https://forum.magicmirror.builders/post/83753</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83753</guid><dc:creator><![CDATA[cyberphox]]></dc:creator><pubDate>Tue, 20 Oct 2020 11:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Tue, 20 Oct 2020 01:05:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> That is really AWESOME!</p>
]]></description><link>https://forum.magicmirror.builders/post/83741</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83741</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 20 Oct 2020 01:05:55 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Wed, 14 Oct 2020 18:26:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alphons" aria-label="Profile: Alphons">@<bdi>Alphons</bdi></a> - Yep. The boss bought a package of spooky videos from AtmosphereX. They’re designed to be run on your TV or projected onto your wall or windows as part of your Halloween decorations.</p>
<p dir="auto">I edited a few of them together into a 3 minute video and set it to play on a loop.</p>
]]></description><link>https://forum.magicmirror.builders/post/83369</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83369</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 14 Oct 2020 18:26:10 GMT</pubDate></item><item><title><![CDATA[Reply to Happy Halloween! I kinda took over the office mirror for a month on Tue, 13 Oct 2020 07:22:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> looks great. Is it a video file that you played?</p>
]]></description><link>https://forum.magicmirror.builders/post/83258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83258</guid><dc:creator><![CDATA[Alphons]]></dc:creator><pubDate>Tue, 13 Oct 2020 07:22:46 GMT</pubDate></item></channel></rss>
