<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-RTSPstream won't shut off.]]></title><description><![CDATA[<p dir="auto">When i use my mirror to show photo’s my camera stream frame stays in front of the photo. It will not go to the background. What causes this problem?</p>
]]></description><link>https://forum.magicmirror.builders/topic/13829/mmm-rtspstream-won-t-shut-off</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 14:06:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13829.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Oct 2020 08:19:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Mon, 19 Oct 2020 10:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a> I changed the stream to VLC and now it works. When i open a photo, the streaming module goes to the background.</p>
]]></description><link>https://forum.magicmirror.builders/post/83718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83718</guid><dc:creator><![CDATA[Alphons]]></dc:creator><pubDate>Mon, 19 Oct 2020 10:24:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Sat, 17 Oct 2020 06:49:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> said in <a href="/post/83560">MMM-RTSPstream won't shut off.</a>:</p>
<p dir="auto">Alphons: that’s exactly how the various streams are designed to act. It’s not a problem of the module, it’s a problem of the stream itself. You have to stop the stream in order to make the stream go away.</p>
<p dir="auto">I tried to tell am</p>
]]></description><link>https://forum.magicmirror.builders/post/83597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83597</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Sat, 17 Oct 2020 06:49:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Fri, 16 Oct 2020 22:17:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> ah… ugh</p>
]]></description><link>https://forum.magicmirror.builders/post/83567</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83567</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 16 Oct 2020 22:17:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Fri, 16 Oct 2020 22:00:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> There’s no iFrame for the stream. It’s painted directly to the screen, the module just launches it and cuts room out of the screen for it.</p>
<p dir="auto">OMX Don’t care.</p>
]]></description><link>https://forum.magicmirror.builders/post/83566</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83566</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Fri, 16 Oct 2020 22:00:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Fri, 16 Oct 2020 18:59:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> I think he wants to change the z-order of the stream iframe</p>
]]></description><link>https://forum.magicmirror.builders/post/83562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83562</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 16 Oct 2020 18:59:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Fri, 16 Oct 2020 18:29:57 GMT]]></title><description><![CDATA[<p dir="auto">Alphons: that’s exactly how the various streams are designed to act. It’s not a problem of the module, it’s a problem of the stream itself. You have to stop the stream in order to make the stream go away.</p>
]]></description><link>https://forum.magicmirror.builders/post/83560</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83560</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Fri, 16 Oct 2020 18:29:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Fri, 16 Oct 2020 12:30:15 GMT]]></title><description><![CDATA[<p dir="auto">Thats not what i mean. When i ask MM to show my photos, all my modules go to the background and the photo is in the foreground except the camera stream. So i have a photo with a camera stream frame within. Thats annoying.</p>
]]></description><link>https://forum.magicmirror.builders/post/83531</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83531</guid><dc:creator><![CDATA[Alphons]]></dc:creator><pubDate>Fri, 16 Oct 2020 12:30:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RTSPstream won't shut off. on Wed, 14 Oct 2020 18:21:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alphons" aria-label="Profile: Alphons">@<bdi>Alphons</bdi></a> If using omxplayer stop the service in pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/83366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83366</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Wed, 14 Oct 2020 18:21:26 GMT</pubDate></item></channel></rss>
