<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[spotify &amp; clock on assistant]]></title><description><![CDATA[<p dir="auto">Hi<br />
I have installed the google assistant and assistant2display, I can play youtube videos but no Spotify, I have an account with Spotify but no premium, it works from my smartphone, but it doesn’t show on the mirror when I ask the assistant, and how can I set the assistant’s clock correctly because when I ask how late it is, he is one hour behind</p>
]]></description><link>https://forum.magicmirror.builders/topic/13830/spotify-clock-on-assistant</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 23:35:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13830.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Oct 2020 11:24:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to spotify &amp; clock on assistant on Wed, 14 Oct 2020 15:44:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raf" aria-label="Profile: raf">@<bdi>raf</bdi></a> i do not know… that is part of the module u are talking to…  i don’t know how it works…</p>
<p dir="auto">i am a volunteer here, maybe having used  10 modules.</p>
<p dir="auto">you will  need to involve the author, unless someone else has already done this and is able/willing to help</p>
]]></description><link>https://forum.magicmirror.builders/post/83343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83343</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Oct 2020 15:44:57 GMT</pubDate></item><item><title><![CDATA[Reply to spotify &amp; clock on assistant on Wed, 14 Oct 2020 15:41:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> why do i have to say to the mirror: youtube play queen instead of play queen on youtube otherwise he doesn’t understand me<br />
(he understands exactly only a wrong sentence’s construction) and the clock is one hour wrong when I ask the hour, where can I adjust this?</p>
]]></description><link>https://forum.magicmirror.builders/post/83342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83342</guid><dc:creator><![CDATA[raf]]></dc:creator><pubDate>Wed, 14 Oct 2020 15:41:34 GMT</pubDate></item><item><title><![CDATA[Reply to spotify &amp; clock on assistant on Wed, 14 Oct 2020 12:39:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> oh, you need Spotify premium to play on other devices ( still only one at a time)</p>
]]></description><link>https://forum.magicmirror.builders/post/83339</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83339</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Oct 2020 12:39:01 GMT</pubDate></item><item><title><![CDATA[Reply to spotify &amp; clock on assistant on Wed, 14 Oct 2020 12:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raf" aria-label="Profile: raf">@<bdi>raf</bdi></a> those just show what is playing somewhere, but do not provide the player for pi.</p>
<p dir="auto">if librespot or raspotify is installed and running (this is a system module, not mm), using the Spotify Connect app on Windows you should see the pi device by the name configured by each.<br />
and be able to.play on the pi, using the connect app.<br />
( no Spotify connect app currently exists for pi)</p>
]]></description><link>https://forum.magicmirror.builders/post/83329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83329</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Oct 2020 12:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to spotify &amp; clock on assistant on Wed, 14 Oct 2020 11:44:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I installed MMM-Spotify and MMM-Nowplayingonspotify a while ago to the mirror, then it will probably be a setting in the config.js file but I think these are good</p>
]]></description><link>https://forum.magicmirror.builders/post/83327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83327</guid><dc:creator><![CDATA[raf]]></dc:creator><pubDate>Wed, 14 Oct 2020 11:44:14 GMT</pubDate></item><item><title><![CDATA[Reply to spotify &amp; clock on assistant on Wed, 14 Oct 2020 11:32:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raf" aria-label="Profile: raf">@<bdi>raf</bdi></a> u have to.install one of the player libs on pi. I thought Assistant2Display installed librespot.</p>
<p dir="auto">there is also raspotify.</p>
]]></description><link>https://forum.magicmirror.builders/post/83326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83326</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Oct 2020 11:32:19 GMT</pubDate></item></channel></rss>
