<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen with cursor]]></title><description><![CDATA[<p dir="auto">Hello everybody.</p>
<p dir="auto">Today I did some work on my mirror again.<br />
I installed two modules and configured them.<br />
With one I made the mistake of using “npm install” in the “Magic Mirror” folder.<br />
However, everything went normally for the time being.</p>
<p dir="auto">After further settings in the config and another restart, the screen remained black with a cursor in the upper corner.</p>
<p dir="auto">I hope you can help me and all my work has not been in vain.</p>
]]></description><link>https://forum.magicmirror.builders/topic/13834/black-screen-with-cursor</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 16:26:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13834.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Oct 2020 18:13:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen with cursor on Sun, 18 Oct 2020 16:40:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> well. 2.13  is current. lots of fixes since then. but if it’s working for you…</p>
]]></description><link>https://forum.magicmirror.builders/post/83684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83684</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 18 Oct 2020 16:40:25 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Sun, 18 Oct 2020 16:34:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Yes… I think i have 2.3.</p>
<p dir="auto">Should i Update the System?</p>
]]></description><link>https://forum.magicmirror.builders/post/83683</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83683</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Sun, 18 Oct 2020 16:34:28 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Sat, 17 Oct 2020 18:36:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> ok , you must be running an older version… we moved that in 2.10 to the MagicMirror/js folder to prevent the file being erased by an npm security cleanup feature</p>
]]></description><link>https://forum.magicmirror.builders/post/83622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83622</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Oct 2020 18:36:24 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Sat, 17 Oct 2020 17:09:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
it was the Module Node_helper.</p>
<p dir="auto">I did this:<br />
git checkout modules/node_modules/node_helper/index.js</p>
]]></description><link>https://forum.magicmirror.builders/post/83618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83618</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Sat, 17 Oct 2020 17:09:21 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Fri, 16 Oct 2020 15:13:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> and what did u do to get it back?</p>
<p dir="auto">is this the ~/MagicMirror/js/node_helper.js<br />
or the module node_helper.js</p>
]]></description><link>https://forum.magicmirror.builders/post/83543</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83543</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 16 Oct 2020 15:13:09 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Fri, 16 Oct 2020 15:11:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Maybe my last installed Module “destroyed” the file.<br />
It was the MMM-WiFiPassword</p>
]]></description><link>https://forum.magicmirror.builders/post/83542</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83542</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Fri, 16 Oct 2020 15:11:16 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Thu, 15 Oct 2020 11:38:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> thanks for the feedback, but I’d like to understand what happened. I put a fix I  a few releases ago to stop the node_helper.js file from being erased.</p>
]]></description><link>https://forum.magicmirror.builders/post/83418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83418</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Oct 2020 11:38:42 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Thu, 15 Oct 2020 07:15:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I got it.  Node_helper was replaced and it worked immediately.  I’m so glad the work wasn’t in vain.</p>
]]></description><link>https://forum.magicmirror.builders/post/83399</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83399</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Thu, 15 Oct 2020 07:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Thu, 15 Oct 2020 02:12:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> show more of log please</p>
]]></description><link>https://forum.magicmirror.builders/post/83372</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83372</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Oct 2020 02:12:12 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Wed, 14 Oct 2020 18:29:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I think, i am on Version 2.1.3</p>
<p dir="auto">Pm2 logs says : cannot find Module “node_helper”.</p>
<p dir="auto">Could that be my problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/83371</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83371</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Wed, 14 Oct 2020 18:29:17 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen with cursor on Wed, 14 Oct 2020 18:24:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> are u on version 2.13?</p>
<p dir="auto">see the translation problem fix at the top of the troubleshooting section?</p>
]]></description><link>https://forum.magicmirror.builders/post/83368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83368</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Oct 2020 18:24:26 GMT</pubDate></item></channel></rss>
