<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I'm trying to get MMM-MQTTbridge to work, but where do I find the debug log to see notifications etc?]]></title><description><![CDATA[<p dir="auto">Hi All</p>
<p dir="auto">I had this up and running before the latest updates to MM and to the MMM-MQTTbridge. But now it doesn’t.<br />
I need to find out what is going on, but where do I find the debug log on the latest MM?<br />
I can see in my old posts when I originally tried to set this up I could get nice long logs that detailed what was going on, but I can’t find the logs now.</p>
<p dir="auto">I need to have the MMM-MQTTbridge report status of monitor (to update the switch in HomeAssistant), to receive monitoron/off (which is sent from a homebuilt PIR in the bathroom) and to execute a custom command (for halloween scary stuff :-D ).</p>
]]></description><link>https://forum.magicmirror.builders/topic/13850/i-m-trying-to-get-mmm-mqttbridge-to-work-but-where-do-i-find-the-debug-log-to-see-notifications-etc</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 07:02:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13850.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Oct 2020 07:01:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I'm trying to get MMM-MQTTbridge to work, but where do I find the debug log to see notifications etc? on Fri, 16 Oct 2020 07:41:03 GMT]]></title><description><![CDATA[<p dir="auto">Ahh, and the second you post this, you actually find it mentioned in a sentence on the forum :-D</p>
<p dir="auto">So if I issue</p>
<pre><code>pm2 logs
<p dir="auto">I see the logs I need!</p>
<p dir="auto">I’m going to break this post off, and make a seperate about the problem with nothing happening now.</p>
]]></description><link>https://forum.magicmirror.builders/post/83521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83521</guid><dc:creator><![CDATA[fribse]]></dc:creator><pubDate>Fri, 16 Oct 2020 07:41:03 GMT</pubDate></item></channel></rss>
