<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar fetch issues]]></title><description><![CDATA[<p dir="auto">Hello, I have seen the following errors in the log for calendars and am looking for help to resolve them.</p>
<p dir="auto">The first issue appears it may be a legit 503 service unavailable issue, but does throw an error into the log.</p>
<pre><code>[2020-10-14 13:34:33.657] [ERROR]  Calendar Error. Could not fetch calendar:  http://p42-calendars.icloud.com/published/2/MjE1NDI5NjM0Mj*MASKED*--sxGM 503: Service Temporarily Unavailable
[2020-10-14 18:53:07.815] [ERROR]  Calendar Error. Could not fetch calendar:  http://p64-calendars.icloud.com/published/2/AAAAAAAAAAAAAA*MASKED*Cj9UqU 503: Service Temporarily Unavailable
<p dir="auto">I have also seen the following error but they don’t always coincide with the 503 errors so not sure if they are related or not.</p>
<pre><code>[2020-10-15 00:44:37.926] [ERROR]  Calendar Error. Could not fetch calendar:  http://p42-calendars.icloud.com/published/2/MjE1NDI5NjM0Mj*MASKED*--sxGM Error: getaddrinfo EAI_AGAIN p42-calendars.icloud.com
    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
  errno: 'EAI_AGAIN',
  code: 'EAI_AGAIN',
  syscall: 'getaddrinfo',
  hostname: 'p42-calendars.icloud.com'
[2020-10-15 01:02:13.529] [ERROR]  Calendar Error. Could not fetch calendar:  http://recollect.a.ssl.fastly.net/api/places/03A47F*MASKED*0E18/services/253/events.en-US.ics Error: getaddrinfo EAI_AGAIN recollect.a.ssl.fastly.net
  errno: 'EAI_AGAIN',
  code: 'EAI_AGAIN',
  hostname: 'recollect.a.ssl.fastly.net'
[2020-10-15 01:02:41.306] [ERROR]  Calendar Error. Could not fetch calendar:  http://p64-calendars.icloud.com/published/2/AAAAAAAAAAAAAA*MASKED*Cj9UqU Error: getaddrinfo EAI_AGAIN p64-calendars.icloud.com
  errno: 'EAI_AGAIN',
  code: 'EAI_AGAIN',
  hostname: 'p64-calendars.icloud.com'
[2020-10-15 01:03:44.890] [ERROR]  Calendar Error. Could not fetch calendar:  http://ical.mac.com/ical/US32Holidays.ics Error: getaddrinfo EAI_AGAIN ical.mac.com
  errno: 'EAI_AGAIN',
  code: 'EAI_AGAIN',
  hostname: 'ical.mac.com'
<p dir="auto">Thanks again for any help!</p>
<p dir="auto">Rick</p>
]]></description><link>https://forum.magicmirror.builders/topic/13855/calendar-fetch-issues</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 03:58:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13855.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Oct 2020 22:54:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar fetch issues on Mon, 20 Dec 2021 16:33:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigtj" aria-label="Profile: bigtj">@<bdi>bigtj</bdi></a> almost every server has gone to secure connection</p>
<p dir="auto">https://</p>
<p dir="auto">not</p>
<p dir="auto">http://</p>
]]></description><link>https://forum.magicmirror.builders/post/97656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97656</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Dec 2021 16:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar fetch issues on Mon, 20 Dec 2021 10:18:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have been experiencing similar errors. I can live with the errors as suggested but the error stops my wallpaper module from displaying my list list of background pictures. The current picture does not change following an error with the calendar. Can the error somehow be prevented from affecting other modules?<br />
Help would be greatly appreciated…</p>
]]></description><link>https://forum.magicmirror.builders/post/97644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97644</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Mon, 20 Dec 2021 10:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar fetch issues on Fri, 16 Oct 2020 23:21:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vvrangler" aria-label="Profile: vvrangler">@<bdi>vvrangler</bdi></a> my pleasure…</p>
]]></description><link>https://forum.magicmirror.builders/post/83585</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83585</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 16 Oct 2020 23:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar fetch issues on Fri, 16 Oct 2020 23:20:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for the explanation, I will not worry too much about those errors then.</p>
<p dir="auto">I have had some mysterious lockups on the MM and so I am just trying to resolve what I can from the logs to better pin it down, I really appreciate all the help!</p>
]]></description><link>https://forum.magicmirror.builders/post/83584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83584</guid><dc:creator><![CDATA[vvrangler]]></dc:creator><pubDate>Fri, 16 Oct 2020 23:20:44 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar fetch issues on Sun, 18 Oct 2020 12:35:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vvrangler" aria-label="Profile: vvrangler">@<bdi>vvrangler</bdi></a> yes, the error handler is verbose… assuming that if there were persistent problems, one would like to know.</p>
<p dir="auto">EAI_AGAIN</p>
<p dir="auto">some network problem in the lower layers causing the code to be unable to resolve the name in the URL to the ip address of the server…</p>
<p dir="auto">503  many times servers are taken down for some kind of service, without warning, and sometimes they fail unexpectedly…</p>
<p dir="auto">nothing we can do on our side for either… except report, and if it continues to cause your solution a problem, when you will research the cause…</p>
<p dir="auto">EAI_AGAIN to me has almost always been cased by some local dns cacher, like pihole   or somesuch</p>
]]></description><link>https://forum.magicmirror.builders/post/83576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83576</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 18 Oct 2020 12:35:25 GMT</pubDate></item></channel></rss>
