<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Show MirrorContent in other browsers]]></title><description><![CDATA[<p dir="auto">Hi friends,<br />
on my pi i have mm and openhab running.<br />
Accessing from any browser in the lan obenhab via ip:8080 works fine (i can see the dashboards)<br />
Trying to access mm via ip:8081 (8081 is the port from my config) does not work.<br />
Do i need to “switch on” this function with some config task?<br />
Thanks<br />
Regards</p>
]]></description><link>https://forum.magicmirror.builders/topic/13877/show-mirrorcontent-in-other-browsers</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 09:20:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13877.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Oct 2020 18:41:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Show MirrorContent in other browsers on Mon, 19 Oct 2020 18:57:35 GMT]]></title><description><![CDATA[<p dir="auto">Works<br />
Thanks a lot</p>
]]></description><link>https://forum.magicmirror.builders/post/83730</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83730</guid><dc:creator><![CDATA[Vauxdvihl]]></dc:creator><pubDate>Mon, 19 Oct 2020 18:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to Show MirrorContent in other browsers on Mon, 19 Oct 2020 18:48:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vauxdvihl" aria-label="Profile: Vauxdvihl">@<bdi>Vauxdvihl</bdi></a> change the port in config.js<br />
if u need to access from outside the pi,<br />
set address:“0.0.0.0”, and ipWhitelist:[],</p>
]]></description><link>https://forum.magicmirror.builders/post/83729</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83729</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 19 Oct 2020 18:48:24 GMT</pubDate></item></channel></rss>
