<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[fresh install MM2.1 with this error]]></title><description><![CDATA[<p dir="auto">Hi,<br />
pi@raspberrypi:~/MagicMirror $ npm start<br />
/usr/lib/node_modules/npm/node_modules/glob/node_modules/fs.realpath/index.js:1<br />
(function (exports, require, module, __filename, __dirname) {</p>
<p dir="auto">SyntaxError: Invalid or unexpected token<br />
at Object.exports.runInThisContext (vm.js:76:16)<br />
at Module._compile (module.js:542:28)<br />
at Object.Module._extensions…js (module.js:579:10)<br />
at Module.load (module.js:487:32)<br />
at tryModuleLoad (module.js:446:12)<br />
at Function.Module._load (module.js:438:3)<br />
at Module.require (module.js:497:17)<br />
at require (internal/module.js:20:19)<br />
at Object. (/usr/lib/node_modules/npm/node_modules/glob/glob.js:44:10)<br />
at Module._compile (module.js:570:32)</p>
<p dir="auto">What’ s wrong? I need help from an expert!<br />
Thank you</p>
]]></description><link>https://forum.magicmirror.builders/topic/1389/fresh-install-mm2-1-with-this-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:54:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1389.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jan 2017 11:44:30 GMT</pubDate><ttl>60</ttl></channel></rss>
