<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;No Signal&quot; message when PIR sensor is triggered]]></title><description><![CDATA[<p dir="auto">The MMM-PIRSensor is working perfectly. Unfortunately when the sensor times out due to no presents detected I get a blue screen with “No Signal” on my monitor/screen.  Here’s my config:</p>
<pre><code> {
		module: 'MMM-PIR-Sensor',
		position: "top_center", // Remove this line to avoid having an visible indicator
			sensorPin: 22,
			powerSaving: true,
			powerSavingDelay: 10, // Turn HDMI OFF after 60 seconds of no motion, until motion is detected again
			preventHDMITimeout: 1, // Turn HDMI ON and OFF again every 4 minutes when power saving, to avoid LCD/TV timeout
			supportCEC: true,
			presenceIndicator: "fa-eye", // Customizing the indicator
			presenceOffIndicator: "fa-eye", // Customizing the indicator
			presenceIndicatorColor: "#f51d16", // Customizing the indicator
			presenceOffIndicatorColor: "#2b271c" // Customizing the indicator
<p dir="auto">I have enabled HDMI CEC on my monitor. I just want it to go dark. any suggestions?<br />
Thanks in advance!!</p>
]]></description><link>https://forum.magicmirror.builders/topic/13893/no-signal-message-when-pir-sensor-is-triggered</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 01:39:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13893.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Oct 2020 16:17:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Tue, 03 Nov 2020 18:07:11 GMT]]></title><description><![CDATA[<p dir="auto">Long time ago I visited this forum, so I don’t know if this will help. but the MMM-ModuleScheduler can hide all modules per notifications. So maybe you can trigger the module with your pir-module.<br />
Or take a look at point 6 in this tutorial<br />
<a href="https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app/2">https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app/2</a></p>
]]></description><link>https://forum.magicmirror.builders/post/84246</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84246</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Tue, 03 Nov 2020 18:07:11 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Tue, 03 Nov 2020 17:04:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> right, u need to turn off the monitor, not the HDMI signal…  some monitors support that. some don’t  (none of mine do)…</p>
]]></description><link>https://forum.magicmirror.builders/post/84241</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84241</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 03 Nov 2020 17:04:24 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Tue, 03 Nov 2020 16:57:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uros76" aria-label="Profile: uros76">@<bdi>uros76</bdi></a> I am using a 3B+ and I have tried the MMM-NewPIR module and it appears to behave the same with my monitor. As soon as I turn off the HDMI port via the PIR module I get “No Signal”</p>
]]></description><link>https://forum.magicmirror.builders/post/84240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84240</guid><dc:creator><![CDATA[steverichab]]></dc:creator><pubDate>Tue, 03 Nov 2020 16:57:13 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Tue, 03 Nov 2020 16:54:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> the real issue here is, can I blank and restore the MagicMirror modules using the PIR module in MM2?</p>
<p dir="auto">Would either of these two options work from within the PIR module?</p>
<p dir="auto">I keep trying to find a hide or show all(modules) command that I could trigger from within the PIR module similar to the “powerSaving” command that turns off the HDMI port but unfortunately causes the “no Signal” message to appear.</p>
<p dir="auto">Thanks Again</p>
]]></description><link>https://forum.magicmirror.builders/post/84239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84239</guid><dc:creator><![CDATA[steverichab]]></dc:creator><pubDate>Tue, 03 Nov 2020 16:54:32 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Sun, 25 Oct 2020 11:57:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> there are two different ways to turn off the hdmi monitor.</p>
<p dir="auto"><code>vcgencmd display_power 0</code> turns of the hdmi controller. The monitor will go into standby mode after that.<br />
<code>tvservice -o</code> is another option. It probably does the same but I’m not sure. MIght work better and send the monitor directly into sleep.<br />
Both commands are bash commands and can be tried from an ssh shell.<br />
if you try out the tvservice command you might need a more complex command to get the mirror GUI back.</p>
<pre><code>/opt/vc/bin/tvservice -p; sudo /bin/chvt 6; sudo /bin/chvt 7
]]></description><link>https://forum.magicmirror.builders/post/83931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83931</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Sun, 25 Oct 2020 11:57:31 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Sun, 25 Oct 2020 07:14:05 GMT]]></title><description><![CDATA[<p dir="auto">Are you on Pi 4 perhaps? I also got the same problem with the module mentioned above.<br />
Then I switched to this one and it works <a href="https://github.com/bugsounet/MMM-NewPIR" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bugsounet/MMM-NewPIR</a></p>
]]></description><link>https://forum.magicmirror.builders/post/83921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83921</guid><dc:creator><![CDATA[uros76]]></dc:creator><pubDate>Sun, 25 Oct 2020 07:14:05 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Sat, 24 Oct 2020 05:20:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> Hi, there are other PIR modules that support hiding out of the box like <a href="https://github.com/bugsounet/MMM-NewPIR" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-NewPIR</a> or mine <a href="https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Screen-Powersave-Notification</a>.<br />
My module needs my GPIO module to get triggered. You ca find a complete example <a href="https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-DE.md" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
]]></description><link>https://forum.magicmirror.builders/post/83882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83882</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Sat, 24 Oct 2020 05:20:00 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Sat, 24 Oct 2020 01:54:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a>  Thanks, I hope you come up with something. As I said the frame is functioning perfectly except for the “no signal” problem. The MMM-Remote-Control module is tempting but I was not able to figure out how to “hide” everything when the PIR sensor triggered.</p>
]]></description><link>https://forum.magicmirror.builders/post/83880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83880</guid><dc:creator><![CDATA[steverichab]]></dc:creator><pubDate>Sat, 24 Oct 2020 01:54:09 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 21:17:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> said in <a href="/post/83838">"No Signal" message when PIR sensor is triggered</a>:</p>
<pre><code> {
			sensorPin: 22,
			powerSaving: true,
			supportCEC: true,
<p dir="auto">I have the same issue, and I am sure there was a time I got the monitor turned off directly with another module.<br />
I think there are different ways of turning the monitor off, at least for more recent Raspberry Pis and this module might be using the wrong one for us.<br />
I wanted to look into this more, you motivated me again :-).</p>
]]></description><link>https://forum.magicmirror.builders/post/83852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83852</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 23 Oct 2020 21:17:32 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 21:02:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> Wow Serg, My head exploded while trying to get the the MMM-Remote-Control module to “hide” just the calendar module when triggered by the MMM-PIRSensor module.  Could you show or point me to an example of these two modules getting rid of this “no signal” problem.<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/83851</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83851</guid><dc:creator><![CDATA[steverichab]]></dc:creator><pubDate>Fri, 23 Oct 2020 21:02:57 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 19:51:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/serge" aria-label="Profile: Serge">@<bdi>Serge</bdi></a> said in <a href="/post/83843">"No Signal" message when PIR sensor is triggered</a>:</p>
<p dir="auto">mmm-remotecontrol</p>
<p dir="auto">Thank You Serge, not sure how to hide when the PIR sensor module is triggered. I will start to work on it.</p>
]]></description><link>https://forum.magicmirror.builders/post/83845</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83845</guid><dc:creator><![CDATA[steverichab]]></dc:creator><pubDate>Fri, 23 Oct 2020 19:51:55 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 18:05:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> with mmm-remotecontrol you can “hide” all modules. So you will get a clear black screen without “no signal” message.</p>
]]></description><link>https://forum.magicmirror.builders/post/83843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83843</guid><dc:creator><![CDATA[Serge]]></dc:creator><pubDate>Fri, 23 Oct 2020 18:05:44 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 16:29:22 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Sam, As you can tell I’m a newbie but I really appreciate the coaching!</p>
<p dir="auto">Is there a way to simple trigger a black screen saver via the PIRSensor module? really anything but a blue “No Signal” message.</p>
]]></description><link>https://forum.magicmirror.builders/post/83841</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83841</guid><dc:creator><![CDATA[steverichab]]></dc:creator><pubDate>Fri, 23 Oct 2020 16:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 16:25:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> oh, and my TV does the same… the HDMI is turned off at the PI, so the tv shows no input</p>
]]></description><link>https://forum.magicmirror.builders/post/83840</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83840</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 23 Oct 2020 16:25:42 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;No Signal&quot; message when PIR sensor is triggered on Fri, 23 Oct 2020 16:24:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steverichab" aria-label="Profile: steverichab">@<bdi>steverichab</bdi></a> don’t know the answer, but when u paste config or code, please use the code block,</p>
<p dir="auto">after pasting the text, select it, and hit the &lt;/&gt;  button above the editor to wrap the text</p>
]]></description><link>https://forum.magicmirror.builders/post/83839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83839</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 23 Oct 2020 16:24:53 GMT</pubDate></item></channel></rss>
